06-12-2020, 02:24 PM | #1 |
Is this routed correctly?
I am talking about the turn signal harness for the tilt column. It doesn't look right and I can't find any posts about the correct routing of this harness.
[ATTACH] [/ATTACH] Thanks. |
06-12-2020, 03:40 PM | #2 |
Re: Is this routed correctly?
As long as the wires aren't pinched it should be ok.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
06-12-2020, 03:48 PM | #3 |
Yeah i know, I just wanted to run it the correct way.
06-12-2020, 05:06 PM | #4 |
I wouldn't route them they way you did. Mine are routed up through the steering column hole behind the instrument cluster
06-12-2020, 06:14 PM | #5 |
What year and is it a tilt column?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-12-2020, 06:45 PM | #6 |
Old member
Looks right to me.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-12-2020, 07:11 PM | #7 | |
HO455- the truck is a '68 but the tilt column is a 71 or 72, can't remember which year. It's a true truck tilt though. |
06-12-2020, 07:16 PM | #8 |
Old member
X2 what hole is he speaking of. The cover runs them down to the dash then up through the dash and column as it looks like you have it ran.
06-12-2020, 10:41 PM | #9 |
I just rebuilt my column and redid the turn signal switch on my 68. Now I cant for sure say it had never been touched, but the turn signal switch was as filthy as can be, had the original red style hazard knob broken off and the original half moon connector so I would say it wouldn't be too far fetched to think it could possibly be original (car shows 57K and I have an old title from out of state that seems to support that being true mileage).
Anyhow, my wiring was routed differently then shown, in front of that blue bracket (so in between that bracket and what ends up being the back of the temperature gauge of the cluster), not behind it like you have it. Take it for what it is worth. Also, just because I ran into this same problem and nearly stripped out my threads trying to put it all together- I see that the hole where the front of the parking brake bracket mounts doesn't line up real good and is partially obscured by the hole in the black bracket (which actually mounts to the firewall and the brake cylinder hangs off of)….get a second set of hands and have someone pull the bottom of the dash forward when you go to attach that so that everything lines up and you don't start stripping it (I must have spent an hour on that before figuring that out). |
06-13-2020, 09:20 AM | #10 |
Old member
Yes the dash will move on you when all the bolts are removed. I take a punch and put in one of the bolt holes to move it around to line it back up right. It can be a pain though.
06-13-2020, 10:33 AM | #11 |
What I meant is curl the harness before the plate so it rests behind the dash. I would not pinch it between like you have it.
