10-22-2009, 12:25 PM | #1 |
"THE GREEN GOBLIN"
TH400 Kickdown Switch wire where to plug in on fuse block
Hello guys I am excited to be able to take out my truck But I want a working Kickdown...I made a search and found nothing I thought I had asked this question before but found no results can anyone please tell me where the wire goes pluged in on the fuse block. I am about to take my truck out this afternoon and I'd like to test out the Kickdown switch thanks.. Pictuers would be nice...
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net Last edited by petey-pablo; 10-22-2009 at 12:26 PM. |
10-22-2009, 12:28 PM | #2 |
Re: TH400 Kickdown Switch wire where to plug in on fuse block
I am dealing w/th400 kickdown switch right now. Do you have the actual switch on the throttle? I had to buy an aftermarket B&M switch but I think oe or aftermarket the "hot" wire should plug into a switched hot lug in the fuse box. Meaning it is only powered when the key is on, just get your test light out and search for a lug that goes hot when the key is in the run position and you'll be ready to roll. Good luck.
10-22-2009, 12:41 PM | #3 |
Resident Curmudgeon
I put mine in Ign Unfused. Works fine
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
10-22-2009, 03:58 PM | #4 | |
"THE GREEN GOBLIN"
Thank you very much.. I love saving money doing what I can myself with the help of this board......
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net Last edited by petey-pablo; 10-23-2009 at 02:09 AM. |
10-22-2009, 08:14 PM | #5 |
Just find any ignition sourced hotwire under the dash and splice it into that switch.
