Old 11-14-2009, 11:52 AM   #1
Thealien
Thealien's Avatar
Cruise control suggestions
I am in the planning stages of an LS 5.3 swap (engine on the way). It is a drive by wire 2005 which makes adding cruise control easy, just a few wires to connect to some switches.
I am looking for suggestions on either a turn signal stalk with the set/accel/coast switches and wires I could replace my directional stalk with (or connect/weld to my original). I am even open to something I could mount on the dash, console?
Come on you creative people. I know some of you have just the idea I am looking for.
Old 11-14-2009, 12:20 PM   #2
dan42
dan42's Avatar
Re: Cruise control suggestions
Check this bang-up job that the PO did on my Longhorn - it runs off the #1 sparkplug.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-14-2009, 12:22 PM   #3
chevy88
chevy88's Avatar
Now that's creative!!!!!!!
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 11-14-2009, 12:23 PM   #4
Thealien
Thealien's Avatar
Thanks I'm looking for something jus a little cleaner.
Old 11-15-2009, 01:00 AM   #5
70cst
70cst's Avatar
http://www.dakotadigital.com/index.c...cat/cat213.htm
This is what I went with ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-15-2009, 07:50 AM   #6
Thealien
Thealien's Avatar
I don't need anything to control the cruise. The PCM from the 5.3 LS engine will do that. I need an no/off switch with the 3 momentary set/accel/coast switches for the turn signal lever. Dakota digital does have some switches they include with their kit that look like what I am looking for, I wonder if they will sell them seperately?
HND-1 - Universal Cutoff Handle - Secures to existing turn signal handle shaft.
HND-2 - Dash Mount Switch - Can be secured to or under dash for hidden operation. Unit Meaures 2" wide by 1-3/8" high
HND-3 - Replacement GM Handle - Secures with single screw through flat end.
HND-4 - GM "Push In" Handle - For most post '80 GM columns without Wiper Controls.
Old 11-15-2009, 10:19 AM   #7
Rokcrln
Rokcrln's Avatar
I used this handle and bolted it right in for my Rostra CC set up in my 70. For my 72 Tahoe I will be using the same switch for my 2005 5.3L D.B.W as well.
You can buy just the handle but I could not find it quickly.
http://www.summitracing.com/parts/FL...4/?image=large
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-15-2009, 10:55 AM   #8
Thealien
Thealien's Avatar
That is exactly what I am looking for! If you should happen to find just that handle listed somewhere or find a part number please keep me in mind. If I get to the point I need it I guess I could call flaming river or summit.
Old 11-17-2009, 01:31 PM   #9
OldCreek
OldCreek's Avatar
Make sure you research open vs. closed circuit cruise control circuits. Most of these stalks will NOT work. I'm in the middle of this and ended up buying a push button set up and will mount it on the dash or somewhere else.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 09-05-2013, 04:33 PM   #10
bbadfred
bbadfred
bbadfred's Avatar
which push button setup and how did you wire it? I have a rostra switch and cannot get it to work
bbadfred is offline   Reply With Quote
Old 11-17-2009, 02:38 PM   #11
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
interesting. I want to know about doing it on a reg old 350.
wait... don't want to hyjack
LOW DOUGH is offline   Reply With Quote
Old 11-17-2009, 02:45 PM   #12
Hart_Rod
Hart_Rod's Avatar
I think this is what you need. It's what I'm using on my 06 5.3. Only $40 from Dakota.
http://www.dakotadigital.com/index.c...prod/prd50.htm
Hart_Rod is offline   Reply With Quote
Old 11-17-2009, 07:36 PM   #13
Ackattack
Ackattack's Avatar
That's what I'll be using too....have it installed on the column and I'm about to hook it up to the TAC box.
Ackattack is offline   Reply With Quote
Old 11-17-2009, 08:27 PM   #14
Thealien
Thealien's Avatar
Where are you mounting your TAC box? PCM? Any pics? I'm getting real close to starting mine and want as much info and ideas as I can get.
Where are you getting the pins for the TAC box or are you connecting to the factory wires from the donor truck?
Old 11-17-2009, 03:37 PM   #15
Custom 68
Custom 68's Avatar
ok for those of us that are not drive by wire what would you suggest?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-07-2013, 04:17 AM   #16
brad_man_72
the boat guy
brad_man_72's Avatar
The factory hand throttle works, if you still have the stock pedal, but isn't the safest route.
The brick idea might be a little worse, especially with that turbo.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-17-2009, 03:54 PM   #17
joedoozer
is Certifiable
joedoozer's Avatar
This might work......and it should drop right in.
1972 Chevy C10 LWB 350 Auto
Blue with a white roof.
joedoozer is offline   Reply With Quote
Old 11-17-2009, 05:50 PM   #18
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
yeah, I don't see any modifications needed
