Vintage 4x4s
WTB: clutch pedal assembly.
Ideally a hydroboost and hydraulic clutch assembly if they made such a combination. My truck is an 86 K30 with Cummins conversion in progress.
Let me know if you have something. Thanks, Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Re: WTB: clutch pedal assembly.
I have a hydroboost, but not hydraulic clutch if you don't find one. Outta my 74, If you think it'll swap over.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
Vintage 4x4s
I can probably make it work. Pics? Price shipped to 55020?
Too many projects
There is a hydro boost / hydraulic assembly. (I have one to convert my 84 if you need measurements or pictures, but it’s not for sale)
The hydraulic clutch assembly and support rods is the hard to find part, the hydro boost pedal will swap into a vacuum pedal assembly.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
seen a few vac/hydro clutch brake pedal rods come with 2 holes . cut the pin from the removed setup and weld it in and pop the 2 extra studs from the fire wall side and good to go . i personally did it years ago on one and drove it a few years .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Vintage 4x4s
Thanks guys if you have pics that would be great.
Anyone know which trucks got the hydraulic clutch?
85-91 square body style is what you need .
#8 | |
Too many projects
If there are any measurements you need or closeups let me know.
Too many projects
Close up of hydraulic clutch pedal.
![]() Join Date: Jun 2009
What price range are you looking in? The hydroboost brakes seems to be the harder hydraulic pedal assembly to come by.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Vintage 4x4s
I don't know, what are they worth? One yard told me $75 pulled out the door for a mech clutch one.
85-87 had the hydraulic clutch. They are hard to find. I have a set of all three variations:
Auto/vac Auto/hydroboost Manual/ hydroboost Took me a couple years to collect them. Going rate for manual/hydroboost is $300-350 for those that know what they have. For those who don't, I've seen them sell for $50. 95% of them will need rebuilt (bushings, pads, pins welded up and possibly a crossbolt). |
I would think eBay is the best or at least the quickest route to find one. They pop up semi regularly .
If for some reason he doesn't want it, I am interested in purchasing
#15 |
Oops! Didn't realize you werent selling it!
#16 |
Vintage 4x4s
Thanks all for the pics and info. At the price they're going for I need to make sure I could get a chevy clutch master cylinder to work with the clutch setup behind the Cummins for the Getrag. Maybe I should just get a mechanical clutch one and adapt it for the dodge clutch master cylinder. I have the ability to fabricate.
It looks like these have a clutch safety switch? Is that to prevent starting if the clutch is not depressed? Thats a nice upgrade from the 67-72's.
#17 |
Too many projects
Yes, there is a clutch safety switch. That’ll be nice when wiring up cruise control and for general safety, I’ll be wiring into the neutral safety switch circuit (previous automatic truck).
As far as clutch line and master options, I’ve done it two ways: 84 C1500 (truck that the pedals are going in): I plan on a stock GM master with an inverted flare to AN-3 adapter. Premade AN-3 braided stainless line to an adapter in the slave cylinder quick connect (2002 GM NV4500). 68 K20 w/ NV5600: I adapted the dodge master to the chevy firewall. Basically a square flange welded to the firewall that the master pushes into and twists 45 degrees to lock into place, exactly as designed on the Dodge. Then drilled a hole in the pedal and made a pushrod. Upside is that all trans components are “2004 Dodge 2500” when I go to the parts store.
#18 |
Vintage if you still want my hydro/mechanical clutch setup just lmk. I've been stupid busy with work but I'll be out there today and can get it oulled.
#19 |
Vintage 4x4s
I need help. Can someone tell me if this piece is needed and where it goes? I think it goes with this setup but I don't see in the photos here or in other ones online.
#20 |
It mounts to the brake pedal where the rod for the master cylinder attaches. Also, without it, your brake lights won't work.
#21 |
nevermind, i looked at the picture again. I am pretty sure it is for trucks with cruise control
#22 |
Vintage 4x4s
Thanks for your response. Yep, there is a separate bracket that is similar but a little different that pushes on the brake switch. This is the one in the foreground that is by the two rods in the pic below. Do you know if cruise trucks had another switch that this contacted? I assumed that the cruise was deactivated by the brake switch triggering.
#23 |
2 bolts / studs from dash frame down .
this bracket goes on pass side bolt / stud . clutch / brake main unit goes up in the dash . steering column goes up in place on the 2 bolts / studs . once all tight this little bracket gets a single screw threw the dash to its little hole to keep the dash from rattling if i was the guess . i just did this swap 1 week ago .
#24 |
closest pic i got .
left side you see a hex screw in dash just left of column stud hanging down . right side you see open hole for same position . that bracket sadwiches in the mix as i said and then a hex screw goes in to match the other side .
#25 |
Vintage 4x4s
Thank you sweetk30! Great info.
