![]() Join Date: Jun 2013
Front Coil Springs & Shocks Replacement
Due to rust I'm replacing the front coil springs & shocks on my 1970 GMC (1/2 ton). 25 years ago I replaced the straight 6 (250) engine with a V8 (350). I actually like the way the front end sits now (which seems standard height - please see photo) and want to replicate it. My concern is what to buy :
Coils : standard or heavy duty, and do I need a 'drop' to compensate for the motor (weight) change and the coil 'sagging' over time ? Shocks : standard or heavy duty ? Any advice & recommendations is greatly appreciated ![]() |
Re: Front Coil Springs & Shocks Replacement
What are you all using on your trucks (particularly 1/2 ton with V8's) ? Any advice & recommendations is greatly appreciated
I have CPP 1" drop springs and Monroe SensaTracs. They feel great. I also have CPP drop spindles but you won't need those with a factory stance, they don't effect the ride anyway.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
Here's a good link for some different coils that helped Dero make his decision. Good info on coil loads and heights:
http://67-72chevytrucks.com/vboard/s...d.php?t=595472
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
Thank you 'sKnNyPpY' and 'Jahloha'
Should I go with a drop in the Coils and do I need Heavy Duty one's for my truck ?
