Old 04-09-2010, 07:22 PM   #1
6D8_C10
6D8_C10's Avatar
Just got parts from CPP!
I just got my new parts from CPP.
Front end rebuild kit
Modular Dropped spindles
3" front drop springs
5" rear drop springs
Lowered shocks with relocation kit
front and rear sway bars
I also got my Edelbrock LS1 carb conversion kit
with Edelbrock valve covers
And finally I picked up a 71 SWB frame with 5 lug disc brakes
and a 69 cab that has LESS rust than my 68 cab.
I also picked up inner and outer fenders along with a radiator support from "Wasted Income"
I think I will be a little busy this weekend
68 c10 350/th350 winter daily driver
90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver
"Just so we are reminded of those who are held back,
Up front there ought to be a Man in Black". Johnny Cash.
6D8_C10 is offline   Reply With Quote
Old 04-09-2010, 08:47 PM   #2
c10seconds
c10seconds's Avatar
Thumbs up Re: Just got parts from CPP!
Nice! I really like the look of those valve covers
c10seconds is offline   Reply With Quote
Old 04-09-2010, 08:55 PM   #3
tommyd241
tommyd241's Avatar
Nice! Looks like you have some work to do.
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 04-09-2010, 10:33 PM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Nice!
How long did it take to get your parts from CPP?
Zoomin is offline   Reply With Quote
Old 04-09-2010, 10:40 PM   #5
rsavage
rsavage's Avatar
Man, that's a great haul!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-09-2010, 10:41 PM   #6
1971gmcshortbed
1971gmcshortbed's Avatar
Nice! I love the delivery man, how low are you going?
1971gmcshortbed is offline   Reply With Quote
Old 04-10-2010, 12:40 AM   #7
6D8_C10
6D8_C10's Avatar
Originally Posted by Zoomin View Post
Nice!
I had a card hang up, put I finalized my order on Mon, and got my parts on Fri.
Well, I got the 2" drop spindle with 3" drop springs in front.
In the rear I got the 5" drop springs.
I will be getting the Boss 338 staggered 18"s with 245/40/18 and 295/35/18 tires which I think will only be about 24-25" tall?
Maybe somebody could give a guess on how low it will be. I don't think you could get much lower with out doing some notching.
Thanks for the comments.
Old 04-10-2010, 01:15 AM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
What are you doing on here? Get out to the the garage and get to work, Don't forget to take your camera with you though so you can post up some progress pics!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 04-10-2010, 01:31 AM   #9
OARNGESI
OARNGESI's Avatar
Why are you wanting such a short tire
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-10-2010, 09:33 AM   #10
fdbdw
fdbdw's Avatar
I love the brown Santa Clause
fdbdw is offline   Reply With Quote
Old 05-18-2010, 08:42 PM   #11
6D8_C10
6D8_C10's Avatar
Well after I pulled everything apart and discovered a lot of the parts were not good enough to put back on the swb frame.
I started cleaning the LCA and the spring pocket was too far gone. I was afraid that the spring would bust through the bottom. After a few attempts to get used ones, I decided again to go with CPP!
So, last night the fun began.
I got the LCA, upper and lower ball joints, CPP dropped spindle, CPP dropped springs and shocks put on the right side.
Tomorrow will be rotor, bearings, caliper and pads.
Hopefully next week will be the left side, and sway bars, tie rods, steering link, and idler arm all from CPP.
Later will be the CPP rear dropped springs, shocks with shock relocators.
After all suspension is put in place I will start putting in the LM7 with the 200-4r.
I will keep you guys posted.
Old 05-18-2010, 10:07 PM   #12
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
OMG those spindles have some mass to them!
chevytruckluver is offline   Reply With Quote
Old 05-18-2010, 09:21 PM   #13
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Ahhh...I'm going with the 200-4r too! That and a carb'd LY6.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-18-2010, 09:59 PM   #14
6D8_C10
6D8_C10's Avatar
I was going to go carb'd too. I even bought the Edelbrock intake with the MSD ignition controller, because I wanted to go old school and keep it simple.
But, after getting a swb and my ability to build everything up without tearing down my daily driver, i decided to keep the EFI.
I have the complete package: LM7 engine, intake, wire harness, fuse box, MAF, air box, multi sparks, air cond pump, steering pump, alternator, flywheel, and headers. It came from a "running" 99 Silverado with 144k miles on it. All for $600.
I will need to get a under bed gas tank with return fuel lines to be able to make my EFI conversion complete.
Old 05-18-2010, 11:19 PM   #15
68GMCCustom
wow, thats a good deal. from a cost perspective I sometimes wish I had gone used, and went ahead and got everything together including the trans...but... I wanted everything going back on my truck to be new and if not new, newly rebuilt.
those spindles do look beefy!
Kurt -
Old 05-18-2010, 11:27 PM   #16
68 c10 ls2
68 c10 ls2's Avatar
Nice! Just make sure you check your tie rods ends are the right ones for the spindles. I got the stock outer 68 ends when i needed and thier kit was suppose to supply the 73-87 outer end. Just a heads up.
68 c10 ls2 is offline   Reply With Quote
Old 05-19-2010, 01:03 AM   #17
GmcSS
GmcSS's Avatar
Maybe I am an idiot, but is that cross-member backwards? Why are the brake lines in front? Or was it like that on certain years?
GmcSS is offline   Reply With Quote
Old 05-19-2010, 07:06 AM   #18
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
^^ Nice catch??? but one other thing you may want to check is with a 3" drop spring you may have bump stop issues....Like you may have to remove them and go a diff route....
I would like to know about the tie rod ends too...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-19-2010, 09:20 AM   #19
6D8_C10
6D8_C10's Avatar
Yea, I went all new with my last project. Except the engine. I just rebuilt it with new rods and pistons.
I decided this time I wasn't going to worry about it. I am just going to get decent new parts if they need replaced, otherwise I would just rebuild or recondition the old parts. Most of the parts on the SWB were rusted ie calipers and rotors, LCA.
the SWB is a 71. So I ordered all 71 parts from CPP.
So, hopefully I won't have issues.
Well I assuming they are correct. But, thats the way I got them. I will have to look at my '68 to see the difference.
I bought new bump stops. You are talking about the rubber bumpers in the LCA right??? If so, i will check for clearence before i put them in.
Old 05-19-2010, 09:24 AM   #20
Hottrucks
Hottrucks's Avatar
I was worried more about the steering stop part on the LCA..theres lots of fixs but if you have to take it off it will suck to take it off after its in....I found drilling the welds works best if you have to it will keep that new LCA looking that way
Old 05-19-2010, 03:03 PM   #21
GmcSS
GmcSS's Avatar
[QUOTE=6D8_C10;3985093]
QUOTE]
Im just thinking you may run into some brake line issues when you turn if it is not correct
Old 05-19-2010, 08:18 PM   #22
6D8_C10
6D8_C10's Avatar
Here is the cross member looking towards the rear.
So yes the brake lines are in front.
Is it supposed to be that way?
The calipers are on the rear of rotor.
You can see the engine location on the crossmember slopes to the rear.
Old 05-19-2010, 08:23 PM   #23
Hottrucks
Hottrucks's Avatar
Nope but you made me go look at my other frame to be sure..but your brake lines are def in the wrong place...give me 5 and I'll post a pic for yea
mine is a drum truck so I guess that not going to help..wait even disc brake trucks the caliper is on the back of the disc why would the lie be on the front
Old 05-19-2010, 08:37 PM   #24
Hottrucks
Hottrucks's Avatar
trust me this thing has never been modified its a parts frame..it should run from the master to the proportiong valve then down to a T near the X memeber near the drivers feet the other is hard line back to rubber line then T to each rear wheel
Old 05-19-2010, 09:04 PM   #25
6D8_C10
6D8_C10's Avatar
So does the disc brake lines get routed in the front like mine or routed to the rear where the caliper is?
