Old 09-13-2009, 12:57 AM   #1
rome704
rome704's Avatar
Quick Question
Im getting a 68 c10 l6 i was wondering what do i need to switch it over to a v8
like give me list kinda lost and me and the search drive isn't getting along
Roman "LCPL" Planter
The Few The Proud The Marines
rome704 is offline   Reply With Quote
Old 09-13-2009, 09:29 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Quick Question
Been a long time since I converted mine... You didn't say what you have but more than likely it's a six with 3 speed standard trans and manual everything.
I was more fortunate in that I did mine about 20 years ago when parts were more plentiful. I converted mine to a 350 with 350 auto trans, p.s. and power brakes and had a donor truck to take parts from.
motor mounts (I think you can use the six mounts of it's a 250)
Rear of transmission cross member
Radiator for the auto trans
3.08 rear axle off donor truck (Sixes are geared too low)
If there's more stuff, someone else will chime in.
68gmsee is offline   Reply With Quote
Old 09-13-2009, 10:47 AM   #3
rome704
rome704's Avatar
Re: Quick Question
yeah sry its a L6 with the 3 on the tree
thanks for the info
Old 09-13-2009, 05:59 PM   #4
71tahoe
71tahoe's Avatar
Re: Quick Question
I like the snap-your-head-back-to-the-window acceleration so I disagree on needing another rear axle.
Any power steering will need new brackets and probably hoses. To keep the alternator on the driver's side you need short water pump, brackets and pulleys. I would recommend a fan shroud since the fan will be farther from the rad and a 7 blade fan with clutch. I've never put a fan clutch on a short WP so it might only fit a long pump.
To re-use the 3-speed.
Look for a block with the tapped hole by the dipstick boss on the driver's side. It will take a screw-in ball stud for the z-bar. If you choose to use headers, a tweak of the z-bar will likely be necessary for clearance.
Auto:
Rear crossmember, linkage, column or floor shift, auto radiator, cooler lines, starter for auto trans.
71tahoe is offline   Reply With Quote
