![]() Join Date: Dec 2013
tac module mounting?
those of you that reworked the harness but kept the factory layout...where are you mounting your module and where did you run the harness through the firewall? the inner fender isnt an option since im about to be bagged on 22s...
Re: tac module mounting?
Mount it up under the dash on the inside then most all i have done went right on the inner fender. If you don't have room on the inside mount the TAC on the firewall like they were from stock. I think the best thing on the wire running is to un-pin the plug then run it through the cowl and use a smaller grommet than the General did. those are huge.
meowMEOWmeowMEOW
Mine's mounted just above the trans hump on the interior of the firewall. I had a 12x6" hole in the floor, so I just kinda toss it through that.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
