Old 09-16-2004, 02:58 PM   #1
72ShortboxManitoba
Question S10 5 speed trans
I have a mild 350 with the bull low 4speed and would like to convert it to a 5 speed overdrive from a older 4.3L S10. Has anyone done this swap before and what problems and modifications with I run into? I know the disc is difference and also the driveshaft lenght.
I am told that the trans is not super strong but a guy I talked to has one in a 57 wagon behind a 454 and it has held up fine so far, but he dose take it easy on it.
The reason I what to go this way is for milage on the highway and the S10 trans are cheap.
Red 72 Chevy StepSide Short Box 350 4spd.
72ShortboxManitoba is offline   Reply With Quote
Old 09-16-2004, 03:40 PM   #2
dubie
dubie's Avatar
gr8scott51 has done this swap in his truck. Maybe send him a PM and ask for more info. He says it's one of the best things he's ever done for highway travelling.
Look at the link below for more info on his truck
http://67-72chevytrucks.com/vboard/s....php3?t=119438
Where in Manitoba you from?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 09-16-2004, 03:56 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is a t-5 tranny, and I would never use one out of an s-10...the t-5 out of a camaro are stronger...even so, the strongest ones are rated at only 305 foot pounds.
There is a reason the T-5 was NEVER hooked to a 350 in production vehicles.
Old 09-16-2004, 04:17 PM   #4
Deuce
Deuce's Avatar
If you drive it like a whiteman it should last for a long time. I had a T-5 in my 375hp Mustang and I beat it like a red headed stepchild and it held up just fine.
**Disclaimer**
No offence to whitemen or red headed step children
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 09-16-2004, 04:22 PM   #5
Steven Sellers
Steven Sellers's Avatar
Oh boy now I am confused............If they never came attached to the 350 then what was the 5 speed that came with the early 90's 350? i dont know if they came in 2wd 350's but I do know my friend has one in a Z71.
2008 Buick Enclave(wifes new non wrecked)
1996 Jeep Cherokee
2002 2500HD 6.0L (traded)
1998 Jeep Grand Cherokee(wifes/wrecked)
1977 DJ5 postal jeep(mmm lots of fun)
1988 Toyota 2wd p/u(DD, blewup 199,000)
1991 Toyota 2ed p/u (sry just cant break these things)
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end".
Steven Sellers is offline   Reply With Quote
Old 09-16-2004, 04:25 PM   #6
Longhorn Man
That was not a t-5, that was something like NV2400 or something like this. Some one please correct me on that.
Old 09-16-2004, 04:32 PM   #7
Steven Sellers
Oh that might have been the nv4500 then thx i was lost in lala land again, to help him with his search has anyone done the nv???? transfer into the our trucks?
1996 Jeep Cherokee
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
Old 09-16-2004, 04:53 PM   #8
Longhorn Man
Huck has done it...hyd clutch and all. I drove it a couple years ago, VERY nice rig.
NV4500 sounds right.
Old 09-16-2004, 05:00 PM   #9
FormerMember
NV4500 is a granny first gear tranny, NOT found in an S10...
FormerMember is offline   Reply With Quote
Old 09-16-2004, 06:27 PM   #10
Longhorn Man
Is it the granny gear tranny? I'm thinking of the one in mid 90's 1/2 ton pick ups.
We know it isn't an s-10 POS tranny....that's the idea.
Old 09-16-2004, 06:31 PM   #11
Steven Sellers
Apparently the early chevy nv4500 was a really low gear then they changed to the higher first gear like dodge was using...heres the site where I dug that up
http://www.high-impact.net/transmiss...ear/nv4500.htm
1996 Jeep Cherokee
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
Old 09-16-2004, 08:13 PM   #12
Huck
Huck's Avatar
Slick 5 speed conversion
I installed a NV 4300 about 3 years ago. It came out of a 96 Full Size Chevy truck. First gear is not a granny but a normal gear. The trans and bellhousing is basically a single unit. It runs with a hydraulic clutch----master cylinder running a line to a throwout bearing. The unit is in an Aluminum housing which is light weight. You probably save about 150lbs or more in weight. The bellhousing bolts up to the 350 block while the trans is supported with a stock auto crossmember. You convert the clutch linkage under the dash to engage the master cylinder. You need to change the length on the drive shaft. ONly big problem is the trans utilizes a electronic sensed Speedo and I have not found a simple low cost conversion solution to a mechanical driven speedo. I installed a high hump on the cab floor and the shifter mounts forward enough to use a bench or bucket seats with console. 5th gear overdrive is great but---I am running a 307 posi so the gearing is a bit high. Would probably recommend a 342 rear gear for optimum tradeoff of performance, MPG, and balance. The shift throw is short and sweet. I don't know how strong this trans might be for racing but for what I do, it's almost perfect. Total conversion cost about $900. Huck
Huck is offline   Reply With Quote
Old 09-16-2004, 05:55 PM   #13
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
welcome there fellow manitoban - i dont know if that swap will work though...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 09-16-2004, 06:14 PM   #14
flatblackclassic
I'd go for the NV4500 before a T-5 from an S-10. Just my .02
flatblackclassic is offline   Reply With Quote
Old 09-16-2004, 09:35 PM   #15
1972C10
1972C10's Avatar
That Crappy two piece case 5 speed that came in early 90s half ton trucks is a NV3500 They suck Friend of mine tore them out constantly with a 4.3
I belive that the T-5 Is Stronger than the NV3500 As does my local tranmission shop and you can get upgraded parts for A T5 If you break something.
1972C10 is offline   Reply With Quote
Old 09-16-2004, 09:40 PM   #16
Steven Sellers
I agree that the 3500 was not very strong earned a nicee rep in the dodge but are you sure the 350 didnt come with the 4500?
1996 Jeep Cherokee
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
Old 09-16-2004, 10:11 PM   #17
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The NV4500 is a seperate piece from the bellhousing, like a 465 I beleive. If you want a decent T5 get the World class T5 out of a 87-93 Mustang 5.0, GT or LX. They aren't near as strong as a NV4500 but they will live under normal daily driving. People have put over 400 hp through them at the drag strips but they usually dont live long doing that. If you can find a good used Tremec TKO, they have overdrive and will handle over 400 hp all day long. You can get good used ones for probably around $700 or so. You will need an older style bellhousing, I think, like from an older GM muscle car or get a Lakewood bellhousing. The S10 used a weak T5 and on the newer ones used a NV3500.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 09-16-2004, 11:14 PM   #18
Jason71k10
ready for reassembly
Jason71k10's Avatar
the nv4500 was only in 3/4 and 1 ton pick-ups, and it was designed for WORK...The can't be shifted very quickly. they're awesome for a 4x4 though...if you have the $$$ for the conversion
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Jason71k10 is offline   Reply With Quote
Old 09-16-2004, 11:55 PM   #19
gr8scott51
gr8scott51's Avatar
I won't argue the point. I used an S10 T5 (which is the same as the Camaro/Firebird, Jeep, Mustang, etc. just in a different case) because it put the shifter in the correct position to clear a bench seat. You can get some good info on T5 transplants from www.inliners.org - they put theirs behind inline sixes and have had great success. Also www.jtr.com has good info. JTR stands for Jags That Run. They use the T5 in their race cars. There are upgrades that can be done to the T5 to strengthen the weak spot. I don't race my truck (it's a truck - not designed aerodinamically for speed) and I don't tow a trailer, so I don't put any stress on my T5. Like Dubie said, I love 5th gear on the freeways. If you decide you want to look in to the swap a little more, send me a pm - I'll help all I can. Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 09-17-2004, 02:06 AM   #20
1972C10
1972C10's Avatar
Ole Boy On here has a 4500 in a half ton Z71 the 4500 is a hoss Huge cast iron granny low 5 speed Its what i aim to put in my 85C20 One Day Unless I can Score A Granny Six out of an HD :BOWTIE:
Old 09-17-2004, 01:55 PM   #21
72ShortboxManitoba
Thanks for all the input, I think I will be rethinking about the T5 trans, it might be time to quit banging gears (which is fun but a pain in the city traffic) and go with a auto with a overdrive. Since I have plans to hop up the motor a bit more. I don't really want a trans that I fear might pop if I give it jam on the street.
Dubie I live in Winnipeg on the east side, it great here I have at least 12 wrecking yard within 5 kms of my house.
Thanks Guys
Old 09-17-2004, 03:32 PM   #22
grayw0lf
Is the T5 in an S-10 an overdrive transmission?
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 09-17-2004, 05:14 PM   #23
gr8scott51
gr8scott51's Avatar
Yes. Different models have different ratios. Most are .85 to 1, mine is .72 to 1.
Old 09-17-2004, 06:00 PM   #24
72C203503ONTHETREE
The only T5 that will live long behind a V8 is the World class Mustang version, the non world class pre 87 Mustang and 92 back F body T5 are ok, but will not live behind power or weight of a truck.
Have you thought about a T56 six speed out of a 93 up F body or Viper? They will handle much more power and you will have double overdrive, and have three choices of shifter placement. They are expensive, over two grand new but can find them lot cheaper used.
Old 09-17-2004, 06:07 PM   #25
Longhorn Man
Even the world class t-5 isn't all that strong. It is only rated at 305 foot pounds of torque.
If one were to want a 5 spped, and wanted to bang gears a little, but not allthe time, I would say to look at huck's set up real close...I drove it, I like it. I don't know the torque rating of it, but being that it is a truck tranny, and came bolted to 350 engines...I'm sure it is better than the T-5.
All T-5 trannys are overdrive. This came in mustangs, S-10's, camarows, trans ams/firebird, and I think maybe rangers too.
