10-14-2010, 05:11 PM | #1 |
4 3/4 bolt pattern
I have a 72 C10 rear that has 4 3/4 bolt circle.The axles or drums have not been drilled.What is it?
10-14-2010, 07:18 PM | #2 |
Re: 3 3/4 bolt pattern
4 3/4 bolt circle is GM mid size 1950's thru 1980's, chevelle, camaro, skylark, 442, GTo etc. Easy pattern to get wheels for. JJibs
10-14-2010, 07:30 PM | #3 |
Location: Help! I'm in an office park with its own network of freeways!
It was also used on S10s, Astros, and box Caprices ('77-'90).
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
10-15-2010, 02:51 AM | #4 |
10-14-2010, 07:51 PM | #5 |
if its a 12 bolt truck style rear, it could be from a late 60's/early 70's VAN. The early vans had a 4 3/4 " bolt circle. crazyAL
http://community.webshots.com/user/hotrodhorn |
10-14-2010, 08:52 PM | #6 |
Rear is out of a truck unless some of the vans were Trailing arm.The housing has never been cut or welded on.If this is a van.What 5 inch bolt circle axle would fit?
I want to use this rear in my truck because of ratio and the housing is real nice. |
10-15-2010, 02:06 AM | #7 |
Could it be a normal 12 bolt with aftermarket shafts? I believe you can order custom shafts with any reasonable bolt pattern.
Ray |
10-15-2010, 03:11 AM | #8 |
No, the vans were all leaf , & the ones I have run across have a smaller (Nova/Camaro) drum setup. It could be as already mentioned, aftermarket axles. Just a ? tho.....when you measured the bolt circle, did you measure from center of 1 stud, the the "imaginary center" tween 2 studs directly opposite of the 1st one? Im not trying to be goofy, but if you measure from 1 stud to the next one that is farthest away.....you measure will come up about 1/4" short crazyAL
10-15-2010, 07:40 AM | #9 | |
Re: 4 3/4 bolt pattern
69 longhorn is correct, many times this is mis-measured.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
