![]() Join Date: Mar 2019
Where to disconnect steering column
About to perform a cab lift and not sure the correct procedure on disconnecting the steering column.
Should I mark the position on the column? At the rag joint? Or further up at that bolt by the shift linkage? Any suggestions would be appreciated Thanks! Posted via Mobile Device |
Re: Where to disconnect steering column
Disconnect at the rag joint, then you can disconnect at the clamp at the base of the steering column where it comes through the firewall. I mark the shaft and the steering box input shaft to keep from 180 degrees out upon install.
Old member
I'd just take it loose at the shifter linkage. It can only go back on one way where the bolt slides through. No reason to take it a part 2 times just to pick the cab up. Less stuff to have hanging.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 2013
That looks like a 67 - 1 piece shaft , It's not coming apart .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Apr 2017
Grumpy wins! My 68 had this style shaft and it was a pain to get out. I was lucky enough that the bearings in my column were so shot that they had enough play to pull out through the cab and out the driver side door.
1968 GMC C2500 Long Bed Fleetside |
You can just disconnect it at the steering box rag joint and lift , What are your plans ?
