Brake Problems
First time posting here, by the way this is a great page. Long story short, I purchased a 71 c10 that was originally standard. Previous owner had rigged a booster to firewall with out brackets. So I purchased brackets and installed them. Now my brakes are hard as a rock and pedal has about 3 inches of travel. I tried to bleed rear brakes but got no fluid to rear. Im thinking the proportioning valve might be the issue. Im going to purchase a new booster and brake cylinder, but cant find a proportioning valve at the located parts store. I have front disc oand drums in rear. Thanks in advance
The Older Generation
Re: Brake Problems
Have the parts store look it up as a "combination valve". No fluid at the rear cylinders could mean a bad rear rubber brake hose, but I would get the new booster/master/combination valve installed before trying anything else. LockDoc
Re: Brake Problems
Ok thanks, found the master and booster as a combo, you would thinks the proportioning valve be offer in the combo. Thanks
#4 | |
Re: Brake Problems
https://www.summitracing.com/parts/c...up?prefilter=1 |
