04-21-2017, 11:01 AM | #1 |
T5 spacer option
Been looking for a spacer to bolt my T5 to my 250 and ran across this one. All I've seen before were the 1/2" thick aluminum ones. This one is 9 ga steel plate (.1495") . Says you have to cut an inch or so off the bearing retainer collar and maybe 1/8 inch off the input shaft. The price is right. Looks like he's sold a good bit of them and no negative feedback so it seems legit.
Thoughts? https://www.ebay.com/p/?iid=32116849...pp=true&chn=ps |
04-21-2017, 02:11 PM | #2 |
Re: T5 spacer option
That's essentially what I did, I used 3/16" (0.1875) plate, and I've had no problems or regrets with it.
04-21-2017, 02:32 PM | #3 |
Thanks...that's what I like to hear!
04-21-2017, 06:34 PM | #4 |
Hmm. That seems like an awfully skinny spacer - good datat point that a slightly thicker one worked for scoot. Here's how I did it, but I used a 1/2" plate.
http://67-72chevytrucks.com/vboard/s...d.php?t=482069 |
04-21-2017, 07:22 PM | #5 | |
I've read your post a lot the last week jocko |
04-21-2017, 09:02 PM | #6 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-21-2017, 10:37 PM | #7 | |
04-22-2017, 09:42 AM | #8 | |
04-22-2017, 04:58 PM | #9 | |
Here is some info I copied from my website. I hope it helps you. Clutch Disc Options 1988 Astro van with 4.3L engine clutch disc – 14 spline and 11” Option 1: M-PACT clutch systems part # 384212 from Rock Auto Option 2: SACHS BBD4212 from Rock Auto 1984 S10 2.8L V6 uses 9 + 11/16” 14 spline clutch disc
04-22-2017, 06:32 PM | #10 | ||
04-22-2017, 07:20 PM | #11 |
I'm using the Astro Van clutch on mine. Worked great behind the 292 and should work great behind the 5.3 as well.
04-26-2017, 02:58 PM | #12 | |
Got my spacer in the mail today. looks to be a quality piece. Now I want a cnc plasma setup! Hoping I can get everything put together soon! |
04-28-2017, 12:17 PM | #13 |
interested.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
