![]() Join Date: Jan 2009
Will this Work, or am I crazy!!!!
I busted my old motor mount and instead of buying $80 worth of polyurethane...........................................................
![]() weld the nut to the plate: ![]() somethin' like this???? ![]()
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
Droppin' It Like It's Hot!
Re: Will this Work, or am I crazy!!!!
Really? Rubber mounts are really cheap, You still may get some vibration doing what's pictured. If you don't want to foot the bill for poly, at least stick with original. Just my .02.
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
As much as it hurts break down and spend the bread.
I'm not as good as I once was, But I'm as good once as I ever was. |
My design is that bad huh!!!!
Between Trucks...
X3
Beat it to fit, Paint it to match... ![]() |
Not advocating but I think you need to try it and tell us. Here's some things I notice that could cause problems.
1. Make sure the insulator on topside is the same thickness as the old mount. 2. Make sure to use a locknut. Not a spin locknut but one that is dimpled. 3. You might have to enlarge the hole in the tower and put the bolt through a rubber hose too. 4. Get a safety cable to contain the torque if/when it may or may not let go. Not a complete list of "what might go wrong" by any means. Now for a recommendation - go to autozone and spend about $8 for the one designed for that. Then you'll have a backup in case you try it and fail miserably. |
![]() Join Date: Jan 2008
$7.99 each from NAPA online.. spend the $$ and do it right
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
its all about the +6 inches
if/ when it fails, it'll happen when you stab the throttle from a stand still. The engine will lean over, and lock the throttle in that position, possibly even causing more throttle.
Just buy some motor mounts. |
A for effort, and not so good on the result, go get some new mounts and let the cob webs out of your wallet!
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
I assume he's not serious about running those homemade disasters waiting to happen.
you say stuff like this and wonder why people crack on you.
#15 |
#16 | |
Yeah get the cheap mounts if you have to because it's a little risky. I even snapped an iron exhaust maninfold in half once!
![]() You've got steel headers so you're even more likely to damage them. Quote:
I'm gonna second that. Last edited by highperf4x4; 09-18-2009 at 11:59 PM. |
#17 |
My Idea wasn't to be cheap, I wanted an interlocking mount that was tougher than the rubber ones. If I thought the cheap rubber mounts would last, I would put them on there. The ones I have on there now, I put on less than a year ago!!!!! I guess I'll break down and buy the polyurethane.........
#18 |
use stock mounts and add a torque strap too
#19 |
#20 |
![]() Join Date: Sep 2009
I saw a cable from the drivers side manifold to the frame on a 70 once, it looked factory. Maybe a recall/waranty fix.
#21 |
#22 |
resident oilfield trash
Dude you can get a set at auto zone for 30
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#23 |
See???? And you weren't sure if you wanted a 383 or not! hmf
#24 |
Your engine got alot of vibration?
#25 |
well when I put in the 383, I took the motor stands off to paint them, I might not have gotten everything tight enough...........this time I put red loctite and lockwashers!!!!!
