Old 04-15-2012, 09:33 PM   #1
mattpiotr
Headers
i want have headers on my 86 350 with dual original 40s flowmasters, the flange on the header is getting bad and their starting to rust out, im NOT getting the Ceramic Coated ones but im not sure what brand to buy, i kinda want something that gives off some what deeper sound if you guys get what i mean? i came to the conclusion of a few brands
-Summit Racing Headers
-Hooker Headers
-Flowtech Headers
-Headmen Headers
Im sure a few of you out their ran/run some of these brands how many of you like the out come of them? how long do they last? witch brand is worth the time and money?
mattpiotr is offline   Reply With Quote
Old 04-15-2012, 09:37 PM   #2
Shane22696
Shane22696's Avatar
Re: Headers
I'm running summit racing's brand. They're built good and sound real good, but they get REAL hot. If you get any non ceramic coated headers be prepared to deal with the starter getting hot. Unless you get a heat shield or install a remote solenoid it won't start after you run it for a minute until it cools down.
80 K10 350 4 spd
4 Inch lift, 33 inch BFG M/t
Shane22696 is offline   Reply With Quote
Old 04-15-2012, 10:35 PM   #3
mattpiotr
Re: Headers
i got regular headers on the truck now, non ceramic and i never had a starter problem the only problem i do have with them tho is the 2nd plug on the drivers side the plug wire always gets burnt no matter what, boot or no boot and i got the accell shorty plugs the gap between the plug wire and header is just a piece of paper thick
Old 04-15-2012, 10:51 PM   #4
Shane22696
Shane22696's Avatar
Re: Headers
are your headers long tubes or shorties?
80 K10 350 4 spd
Old 04-15-2012, 10:56 PM   #5
mattpiotr
Re: Headers
Long Tubes
Old 04-15-2012, 10:58 PM   #6
Shane22696
Shane22696's Avatar
Re: Headers
Oh cool, I guess you got lucky with your starter lol. How do you have your plug wires routed?
80 K10 350 4 spd
Old 04-15-2012, 11:56 PM   #7
mattpiotr
Re: Headers
well either way im going to get a new set of headers any ways, what brand are you running?
Old 04-15-2012, 11:58 PM   #8
Shane22696
Shane22696's Avatar
Re: Headers
They're Summit brand truck headers. I went ahead and sprayed them with some header paint when I got them and they still look brand new after a few months of daily driving. Definetly worth the money
80 K10 350 4 spd
Old 04-16-2012, 04:22 AM   #9
westie 666
westie 666's Avatar
Re: Headers
I got flowtech long tube and had them coated, no issues at all
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 04-16-2012, 06:25 AM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Headers
Inexpensive ceramic car headers fit! I bought mine on ebay for $169
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-16-2012, 06:30 PM   #11
Cue-Ball
Cue-Ball's Avatar
Re: Headers
I have Flowtech mid-length and have no issues with starter heat, and no issues with plug wire routing (going over the top, next to the valve covers using $20 Mr. Gasket plug routing looms).
However, I would not buy these headers again. I've had nothing but leaks, leaks, and more leaks, and the mounting flanges bent pretty easily when tightening the bolts to the heads. If I replace them I would not even consider buying anything with a flange that's less than a 3/8" thick. Hedman Elites #68648 are at the top of my list.
Cue-Ball is offline   Reply With Quote
Old 04-16-2012, 07:15 PM   #12
thesickc10
Re: Headers
cut in between the moutning flanges off and you will get a better seal. An old hot rodder showed me that. The idea is that by making each mount independent they wont flex the entire flange and stop leaks.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 04-16-2012, 07:28 PM   #13
Cue-Ball
Cue-Ball's Avatar
Re: Headers
I plan on doing that the next time I remove the headers. They're going to have to come back off (again) because the driver's side collector is leaking. While they're off I'm going to do whatever I can to smooth out the mating surfaces and make a good seal. Percy's Dead Soft aluminum gaskets helped a lot compared to the copper gaskets that I used the first time.
Old 04-17-2012, 08:47 PM   #14
Lugnutt
Lugnutt's Avatar
Re: Headers
I've got hedders and I've been having serious starter problems. Basically, my truck won't start after it's been running for awhile until I let it cool off. The hedder comes within 1/2" of my starter motor and about 3/4" from the solenoid. I'm wondering how best to mount a heat shield and what material to use. I've got some 16ga. copper sheet that might disipate the heat well. I'm thinking about screwing it right to the hedders with some stand-offs.
Lugnutt is offline   Reply With Quote
Old 04-17-2012, 08:55 PM   #15
Shane22696
Shane22696's Avatar
Re: Headers
That might work, but the easiest way to solve it for good is to mount a remote solenoid like on the old F@rds. Just get a starter solenoid for a pre-88 F-150 or so and mount it anywhere you want. I can send you a link with detailed instructions if you want
80 K10 350 4 spd
Old 04-17-2012, 09:05 PM   #16
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
Re: Headers
I would recommend Stan's headers completely. I'm on the 4th year with mine and they're still looking as new as the day i got 'em minus the blue discolaration, and they have nice thick flanges. http://www.stans-headers.com/gm_headers.htm
a picture of the headers i have (454): http://www.stans-headers.com/Photos/154Y.jpg
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 04-18-2012, 03:30 PM   #17
Psycho71
Psycho71's Avatar
Re: Headers
I run hooker Competition Headers on my 85 burb 4x4, and on my '71 C10. I run a mini-starter on both trucks, and have never had a heat soak issue. Hooker is by far the best headers I have ever ran. Gaskets seem to last a LOT longer than I experienced with the cheaper brands. And I like the flat flange on the collectors, as opposed to the ring and flange some companies use.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
