Old 05-03-2013, 10:13 PM   #1
WadmalawJoe
WadmalawJoe's Avatar
What is this light for?
I took my dash cluster out today to disassemble it, clean it and work on getting my temp gauge to work. I had to unplug a odd wire from the odd connected for a light. What is it?
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 05-03-2013, 10:23 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: What is this light for?
not for sure but under my gas gauge, I have a BRAKE and a TEMP. Could that be it?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 05-03-2013, 10:24 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
That is for the fiber optic cable to light up the shift indicator on the steering column.
TBONE1964 is offline   Reply With Quote
Old 05-03-2013, 10:51 PM   #4
Longhorn 70
YES!!! No wonder Mine doesn't work! THANKS.
Old 05-03-2013, 11:00 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
It is a great feeling when ALL the lights work. I discovered mine because the light in the dash was burned out and it was the same one for the optic cable. When I replaced it, the shift indicator also worked.
Old 05-04-2013, 08:14 AM   #6
WadmalawJoe
Thanks Tbone!
I was wondering if that was for that optic cable. The cable is there, but I think the bulb is out, the shift indicator wasn't lit up at all. That cable can't really transfer a whole lot of light anyway can it? I will take that apart and clean it as well. Seems like I read about a led mod you can do for that.
While cleaning and painting inside the dash area with the cluster out, I made an ugly discovery of my wiper motor barely hanging in there. The area around it is severely rusted and you can see out into the cowl area. I'm not looking forward to this repair project.
Toys/projects
Old 05-04-2013, 01:04 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
One thing to make sure of is that the optic cable is not kinked or has any hard bends in it. That will break the flow of light to the shift indicator. I know they make brighter dash light bulbs also. Not sure of the part number.
Good luck with the cowl area. That is a tough spot to repair.
Old 05-04-2013, 05:03 PM   #8
WadmalawJoe
A couple months ago I swapped most of my regular 194 bulbs for the 168's which are much brighter. I didn't pick up enough bulbs to do them all. I need to go grab a few more now that I have the cluster out and its much easier to install bulbs.
Toys/projects
Old 05-04-2013, 05:09 PM   #9
kcsa75
kcsa75's Avatar
Help me out. The fibre optic cable sends light from the dash to the steering column or juice to power a bulb in the steering column. The reason I ask is on my column there is a bulb under the PRNDL. I replaced it but still have no light there.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
