![]() Join Date: Feb 2013
factory BB horsepower?
hi
i got the german papers yesterday to could drive my dolly legaly on the europeen streets ![]() ![]() but in the technical data they wrote the hp are 127kw @3400 rpm...lol they took wrong information somewhere... i will go and let it run on the dyno but that will take a few weeks before i could go;( i have the sales brochure from 71 and 72 in 71 they write: sae net horsepower 240@4400 in 72 : sae net hoorsepower 210@4000 i have a factory 402 from 72 how much does it have? what are these sae net horsepower? hope you guys knew more about it ![]()
Loving my Dolly ![]() Greetings from Germany Andy |
I am a Referee of life.
Re: factory BB horsepower?
SAE stands for Society of Automotive Engineers.The big block in your truck probably put out about 210 when new but unless it's completely stock rebuilt has probably lost some of that.The big engines generally put out a lot more torque.At some point HP was changed a bit I'm not sure whn that happened.You will find that the 210 hp in your truck will not feel the same as 210 in a modern vehicle.A member here has a sig that explains it as "HP is how fast you hit a wall,torque is how far you move it."
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Hi Andy,
The number I calculated is 156.597kw @ 4000 rpm. Even at the 3400 rpm they used it is still about 145kw The page is the factory data sheet for 1972 light trucks as it is noted. Below are some quotes from a site that will help you and they agree with how I understand the ratings and their history. "SAE Net Horspower In 1972, American manufacturers phased in SAE net horsepower. This is the standard on which current American ratings are based. This rating is measured at the flywheel, on an engine dyno, but the engine is tested with all accessories installed, including a full exhaust system, all pumps, the alternator, the starter, and emissions controls. Both SAE net and SAE gross horsepower test procedures are documented in Society of Automotive Engineers standard J1349. Because SAE net is so common, this is the standard we will use to compare all others." "Kilowatts Kilowatts, or kW, is not a different way of measuring engine power; it's just a different unit of measure. Countries that use kilowatts instead of horsepower typically use a rating system very close to SAE net horsepower (usually DIN). To convert kW to SAE net hp, divide the kW value by 0.7457." http://www.hardtail.com/techtips/hpexplained.html
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
thx foe the answers
![]() hmm i hpe i can go to the dyno run soon ![]() greetings
#5 | |
![]() Join Date: Oct 2011
![]() Quote:
ie: Different exhaust? (dual? headers? or?) or perhaps a different intake manifold and carb? or low restriction air cleaner? Rebuilt? or? If so, this should benefit your dyno numbers to some degree...but keep us posted on how it goes All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#6 | |
![]() Join Date: Feb 2003
kinda simular to mine. thx dave
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
To be very clear here. These factory power ratings are for an engine in a test cell with a load dynamometer. While it does have the "as installed" accessories during testing (thus not a "gross" number) it is higher than will be seen in an actual installation and measured at the rear wheels on a chassis dynamometer.
Hi
dolly came today... i find out that i have alreaedy an edelbrock performer inlet with biger carb open aircleaner and a complete exhaust system on it. That is what i can see fron outside. so after the dyno i don t have the ome power data. Posted via Mobile Device
