Old 05-08-2008, 05:32 AM   #1
randomhero472
randomhero472's Avatar
Air ride guys.. anyone fit a 5gal tank under bed?
I really want to keep my tank/compressor out of sight and under the bed, but havent really seen anyone be able to fit one under the bed, anyone make it work.. or what about (2) 3 gallon tanks under the bed... Thanks
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 05-08-2008, 06:00 AM   #2
jimmydean
jimmydean's Avatar
Re: Air ride guys.. anyone fit a 5gal tank under bed?
67Fleet had 2 3-gallon tanks mounted outside the frame rails hidden by the bed just behind the wheels. I mounted a 5 gallon tank between the frame rails.
Mine:
His:
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-08-2008, 06:21 AM   #3
XXL
Seņor Member
XXL's Avatar
3 gallon tanks can be straddled on either side of the driveshaft with some simple bracketry.
XXL is offline   Reply With Quote
Old 05-08-2008, 06:30 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
I have a 68 in the shop right now that we mounted a fat 5 gallon tank in the rear where a fuel cell would normally go... is this where you're referring to? If so, I can get some pics for ya. We made a bracket/tray that holds the compressors/valves/tank. It fits nice and keeps it all hidden, but will not work if you want to get rid of the factory fuel tank behind the seat.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-02-2008, 03:19 AM   #5
tds
wonder if i can dump my exhaust before there so i can mount my tanks like that on my 81. it would be perfect.
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 06-02-2008, 03:34 AM   #6
XXL
Seņor Member
XXL's Avatar
That would put the dumps at/under the back of the cab... noisy and probably not to fun to breathe. There should be plenty of room for exhaust to run through that general area, and to the back.
Old 06-02-2008, 07:32 PM   #7
tds
yea but anything would be better then the open headers i have now. i'll just have to do my exhaust and see what comes of it.
1981 - C-10 SCSB
Old 05-08-2008, 02:29 PM   #8
randomhero472
I should have mentioned i have a blazer tank in the rear, my apologies... I think i might be stuck w/(2) 3 gallon tanks on each side of the frame, but please keep info coming!
Old 05-08-2008, 03:15 PM   #9
los-lowrider
los-lowrider's Avatar
I have mine mounted behind the cab. It's an 5.28 gallon tank.
Best Regards from Germany!
www.los-lowrider.com
los-lowrider is offline   Reply With Quote
Old 05-09-2008, 01:37 AM   #10
Painter D
Painter D's Avatar
I was able to fit a 5 gal. tank under the bed ,on the pass. side outside frame rail ,in front of the back wheel. Its really close to the bed floor supports but it does fit without hanging down too low , you can't see it from the side either.
Painter D is offline   Reply With Quote
Old 05-09-2008, 03:05 AM   #11
randomhero472
You have any pics of it, and have the measurments for the tank?
Old 05-09-2008, 04:45 AM   #12
Painter D
Painter D's Avatar
Give me a day or so to try to find a pic and get on my comp.
