Old 12-24-2006, 12:24 AM   #1
whatnow123
whatnow123's Avatar
step side rear tire size rim width
Can the step side people help out here? I'm wondering what size tire I can fit in the rear of my truck. I pulled off my bed today because I found the right bed for my truck (came with a 66 step side, didn't know the truck well enough to know when I bought it, but now I've got a 68 bed). Anyway, there seems to be quite a bit of room in there with the bed off.
How wide a tire can I run with a stock short bed?
I'm also now thinking of shortening the rear axle a couple of inches, converting to a 5 lug and "mini tub" the bed. Nothing pro street or anything, just widening the wheel well a couple of inches. Is there a shorter axle that I can swap in there or should I just narrow what I have? Truck 12 bolt, (not sure if I should waste the money on this rear end or not or if there is a more cost effective way?)
whatnow123 is offline   Reply With Quote
Old 12-24-2006, 01:01 PM   #2
Bob Moore
Re: step side rear tire size rim width
The 71-72 five lug rearends are a little bit narrower than the six lug ones. About 2 inches or so. Kill 2 birds at the same time - convert to 5 lug and get a narrower axle at the same time.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-24-2006, 02:33 PM   #3
whatnow123
whatnow123's Avatar
I thought this was the opposite? The earlier rear ends were narrower than the 5 lugs?
Old 12-24-2006, 02:01 PM   #4
dcpetty
dcpetty's Avatar
I am running 17x8 w/ 4.5 bs and a 275/55/17 tire. I have about 1 1/2" clearance to the bedside
dcpetty is offline   Reply With Quote
Old 12-24-2006, 03:24 PM   #5
the 69 and earlier 6 lugs are about 1 and 1/2 " narrower. The newer 5 lug axles will permit you to run a bit more backspacing and still not rub.
Old 12-24-2006, 08:55 PM   #6
Bob Moore
My bad. I hope I didn't cause any problems. I always thought the newer were narrower.
vac, 454, T400
more to follow
Old 12-24-2006, 09:31 PM   #7
No biggie Bob. Merry Christmas, let's talk trucks!!!
Old 12-24-2006, 09:56 PM   #8
smbrouss70
smbrouss70's Avatar
According to an e-mail from XXL when I asked about his wheels, he said that he used a 17x8 with 5" backspacing all the way around wearing 255/50-17's. He also noted that on the back he used a 5/16" spacer, and that the 5/16" was critical. Keep in mind that this is with airbags that allow the tire to fully tuck into the stepside fender. Also I believe that he is using an axle from a 71 or 72, which is wider than the earlier years. Maybe he will chime in here and confirm what I've said.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-27-2006, 11:08 PM   #9
Trey`
Active Member
Trey`'s Avatar
I have the same question, I have a 70 and it has the 6 lug rear end. Found some 18x8.5 with 5.5 inch of back spacing and was'nt sure they would fit or look alright and have not gotten a chance to measure yet.
'70 Chevy stepside, ECE discs & 4/6,
'00 GMC ext. cab stepside, never ending project
'07 GMC Crew Cab, 24's & 5/7
"We, the unwilling, led by the unquailified, have been doing the unbelievable for so long with so little, we now attempt, the impossible with nothing"
Trey` is offline   Reply With Quote
Old 12-28-2006, 01:31 AM   #10
kbs71
71 rustless in texas
kbs71's Avatar
Not a step side but I'm running the stock rally 15" X 10" with P295/60/15 on them and I got about 1 1/2" on the outside and 2" inside.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 12-28-2006, 01:50 PM   #11
68Stepbed
68Stepbed's Avatar
Here is my truck with 275/60/15's on an 8" rim with 4.25" bs. The older pic is with 275/60/17's on 17x9.5 rims with 5.5" bs. The 17's rubbed on the inside of the bed with the deep backspacing. A smaller tire or 5" bs would've fixed the problem.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
