![]() Join Date: Feb 2011
Throttle cable question - 72 C20 402 cu.in.
Will the factory throttle cable and carb bracket still function correctly with an Edelbrock Performer PN7164 aluminum intake installed? I noticed the carb will be sitting quite a bit higher on the Performer compared to the OEM cast iron intake.
Pics would be ideal. Thanks in advance.
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Throttle cable question - 72 C20 402 cu.in.
Should be enough slack,
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Thanks Ol Blue...it's the "should" part that has me concerned.
I do not want to make the swap and find out that it does not reach or is binding. My worse fear is to take it back off after it is in the truck. Not a fan of just rigging something either. Hopefully someone on the board has one of these installed on their big block.
TTT...anyone?
I still say it willwork
2WD Jimmy
![]() Join Date: Mar 2005
I have a BB in the stock location. I am running a Holley on an Edelbrock Air Gap manifold. The stock cable had to be shortened about 2 inches. I'm using the stock bracket, but I had to grind on it a little. I don't think anyone could tell any modifications were made to this setup in order to get it to fit.
Posted via Mobile Device |
