Has anyone ever mounted a courtesy light switch on the piller post for the 3rd door to operate the light?
I would like to set one up before we put the ceiling panels in place and I wanted to get a location of where to mount the switch on the pillar post. TIA, Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: 3rd door courtesy light switch
I had the same question, I hope someone pops in with a solution. Cheap is good
Well, I went ahead and installed a courtesy light switch on the 3rd door pillar post and it looks like it will work.
I ran the white, (ground) wire from the switch down inside the pillar to the channel under the front step plate, across the floor and tied it into the white wires that are part of the courtesy light harness. (I had wanted to run the white wire up to the ceiling but could not find a way through the connection of the pillar post to the roof supports). The switch could not be centered on the raised area of the pillar, (ref. attached pic) as the inside reenforcments precluded the location. While we had the ceiling panels off, I made a bracket and installed a rear courtesy light to light the cargo area, (pic attached). Jim
![]() Join Date: Apr 2005
Door switch is a good idea. Have you thought about doing one for the liftgate? Where did you get your perforated panels for the headliner?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Where did you get your door switch?
Hart Rod,
Extra switch for the rear (barn doors on this Burb) is a thought, thanks for the suggestion. I will take a look at what it would take and see if my son likes the idea. The panels have been cleaned and painted. If you are interested I will write up a short description of the process that I went through to paint them and what kind of paint I used. 72GMCburban, The switch that I used is the standard truck door switch as used on the front doors of the 67-72 trucks and burbs. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 04-29-2007 at 08:48 PM. Reason: spelling |
