12-02-2015, 11:31 AM | #1 |
Gas Pedal Options
Curious if anyone has had to come up with a different way to run the throttle pedal. My stock pedal on the GMC, which I assume is the same on the Chevys, is too far toward the passenger side for my engine swap. A cable setup would be the ideal. Is there a cable setup that can be found at an average junkyard that works with fabrication? Our junkyards don't have any 60-66 and almost no 67+ but usually can find some 80's GM. Thanks in advance.
12-02-2015, 11:48 AM | #2 |
Re: Gas Pedal Options
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-02-2015, 12:07 PM | #3 |
Thank you. I saw that when I did a search but unfortunately haven't seen a 71-72 in any junkyard (probably a good thing!).
12-02-2015, 12:37 PM | #4 |
No problem !
I went with a used "spoon " type pedal and a cable /bracket from then Kragans now O'rileys I used a pedal out of a F150 on my old 53 wagon that worked fine. You can try going to pick a pull and see what you can find too
12-02-2015, 01:10 PM | #5 |
Lokar is what I used. Darn sweet setup.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-03-2015, 11:41 AM | #6 |
12-03-2015, 01:41 AM | #7 |
60-66 Nut
I don't think you would absolutely have to use a pedal assembly form a '71-'72. I don't see why an assembly from a '73-'87 wouldn't work. It looks nearly the same as the '71-'72.
12-03-2015, 11:03 AM | #8 |
Thanks all - I will try to find an 80s chevy truck pedal to check out.
12-03-2015, 11:13 AM | #9 |
Try A late 80's or early 90's gas pedal I found one at a swap meet for 5$ and worked perfectly! aka Throttle body type with cable.
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-03-2015, 02:05 PM | #10 |
Moderator
Lokar makes one that will fit as well as the 70's model gas pedal: http://www.ebay.com/itm/Lokar-XBAG-6...JVchWH&vxp=mtr
They also make the same unit not black. But I think I will be using the black one. I have a 72 gas pedal to use but I'm not at home for a few months.
