10-15-2014, 09:16 PM | #1 |
GTO 5.7 motor and trans
has anyone put one of these in our trucks? I have a line on a complete setup out of a wrecked GTO. the motor/trans has 63xxx miles on it. would it be similar as a 5.3 0r 6.0 going into our trucks? I assume it cant be much different. and what would be a fair price for said motor/trans, computer, wiring harness, drive by wire pedal and all engine accessories?
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
10-15-2014, 10:31 PM | #2 |
Re: GTO 5.7 motor and trans
Without oversimplifying it is really pretty close. The intake is gonna be shorter by several inches being a car intake but the block is the same diametrically speaking it will be aluminum instead of cast iron like a truck block[there are a few exceptions] but as far as swapping goes you shouldn't have any problems putting it in there. Jim
10-15-2014, 10:35 PM | #3 |
my friend bought same motor and trans ,,about the same miles on it.
4700.00 thats a good one
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
10-15-2014, 10:40 PM | #4 |
It's a ls1 same motor in a corvette
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
10-16-2014, 04:33 PM | #5 |
It's an LS1 only if it is a 2004 model year motor. In 2005 & 2006 Pontiac used the LS2. In any case, the motor is not the same as the Corvette motor. There are differences internally that de-tune the GTO version. Depending on year, 4700-5500 is a good price.
10-15-2014, 10:52 PM | #6 |
Tommy is this the wrecked one on clist? I almost pounced on it a couple weeks ago lol
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
10-15-2014, 11:03 PM | #7 |
thanks guys for the info, no its not the one from Craigslist. and the price is 4600 so I guess it's fair
sounds like this could be an option in the future
10-16-2014, 12:49 AM | #8 |
if it has a t56 its worth that maybe. if its an auto def. less.
the t 56 on a gto is similar to the corvette one. it has better syncros then the Camaro versions so its a better at shifting. If it is a t56 you will have to convert the tranny to a f body style because the shifter is behind the tranny on a gto. So it will be in the middle of your seat. the only other difference is the starter. its smaller then a f body so will have to match. It really is just an Ls1 motor and for some reason people still want a ton for them. I am sure you could probably get a ls2 setup for that price. good luck either way god bless bpatrol |
10-16-2014, 12:54 AM | #9 | |
10-16-2014, 02:49 AM | #10 |
yea to me not worth that money. go get a 6.0 out of a truck with tranny and you will save some money for the conversion parts u need.
good luck phillip |
10-16-2014, 03:11 PM | #11 |
What he said^^. The last Two 6.0's I sold with pcm and 4L80E and wiring [you know complete pullout type thing] were like $1250 and $1500. So you could by lots of extra parts, body panels, resto stuff, or trucks for that matter. Jim
10-16-2014, 07:14 PM | #12 |
sounds like this is the way I need to go then....
10-16-2014, 07:34 PM | #13 |
sorry Fitz, He stated 5.7 so it has to be a 5.7. It will be identical to a corvette motor. same cam same heads same intake. it is a ls6 motor with ls6 intake 243 heads sodium valves and same cam. internally the same and the best and last ls1/ls6 made. Power might have been slightly higher due to exhaust manifolds but that's it.
Its a nice motor don't get me wrong but there are better cheaper options for a truck at that price. |
10-17-2014, 05:38 AM | #14 | |
2001-2004 Corvette Z06 2004–2005 Cadillac CTS V-Series 2007 SSC Ultimate Aero TT Please note that the GTO is conspicuously absent from this list. Last edited by Fitz; 10-17-2014 at 05:47 AM. |
10-16-2014, 09:02 PM | #15 |
not sure of the year but I know for sure it was a 5.7
10-16-2014, 11:12 PM | #16 |
So far as I recall, and you'll want to check this before making a decision on it, the original LS1 and LS6 could not be bored any further. You'd have to sleeve it during a rebuild.
I think a later LS2, LS3, LQ9 or similar would be better and maybe even cheaper. I would recommend you get the wiring harness and send it out to a specialty shop that can "cut it down" to run your engine without worrying about gauges and all of that.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-17-2014, 07:01 AM | #17 |
It's alsways something.....
I recently bought a LS1 and 4l60E for $2300 inc harness, acessories and PCM with 123k miles.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
10-17-2014, 08:46 AM | #18 |
I'll just look for a 6.0 and call it a day
10-17-2014, 12:20 PM | #19 |
