11-18-2007, 08:24 AM | #1 |
Elec. help needed
Hey Guys,
Okay when I bought my truck I knew it needed a lot of work, mostly to fix the PO’s rigged up messes. Now I’ve got it where it’s running good and I’m driving it to work daily. If you were to look under the dash you would swear Jack the Ripper got loose under there with a pair of wire cutters and some electrical tape. I know I need to do some major re-wiring, but cash is low and Christmas is just around the corner, so I’ve got to keep the spending on myself down. What I would like is to have some dash lights. What I need is to have a working gas gauge. When I cleaned out the gas tank I installed a new sending unit. I checked the wire running from the dash to the tank and it’s a good wire. Now I’m not very good with electrical stuff. Can someone tell me an easy way to run a wire from the gauge to maybe the fuse box and then run the sending unit wire there too maybe? I’m just not sure how to do it. In the spring when I’m Hillbilly rich again I’m going to do it right, but for now I need to do some rigging of my own. Any help will be greatly appreciated. Tim |
11-18-2007, 08:31 AM | #2 |
Hollister, CA.
Re: Elec. help needed
The wire from the fuel tank runs right up the guage it self. The other side of the guage should be 'key-on' 12 volts.
If you don't have one, pick up a test-light, and mabey a wiring diagram. It is not as difficult as you might think. A gray wire feeds all the dash lights, coming from the headlight switch...make sure all the bulbs are ok.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-18-2007, 09:59 AM | #3 |
Hey thanks John!
