![]() Join Date: May 2009
How do I know what options???
Hello, has anyone done this or can anyone tell me
how to find out what options my truck came with from the factory by the VIN# when the truck was built? I have no build sheet or glovebox sticker. Please, if anyone knows how to do this I would greatly appreciate it! Thanks |
![]() Join Date: Jul 2007
Re: How do I know what options???
No way that I know of without the build sheet or spid on the glovebox.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
Yeah, I keep running in to brick walls on this.
Didn't know if someone out there on the forum had any info on where to go. I don't know if you could go to GM and if they kept any records or not. Thanks for the reply. |
#4 | |
As Tim suggests, if your truck was built in Oshawa (or for Canadian sale) you may be able to get the info through GM of Canada. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
You can decode the vin, it will give you a little bit of an idea. Good luck with your search
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
The VIN will tell you a little and a cross check of the frame partial VIN will tell you more. From there it is a matter of how much of the original truck is still there.
But no you can't request a build from a VIN like you can on Canadian trucks. So is your truck an Oshawa (1) built truck?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
