![]() Join Date: Sep 2001
Overdrive Options/Gear Vendor/US Gear/4L80E
Overdrives are certainly nice for our trucks and I have struggled with my options. My 402/TH400 are in good shape but a PO installed 3:73 gears in place of the 3:08. The combination is fun in town but not as fun on the highway. The Gear Vendor solution is around $3,000 and requires me to mount some electronics and shorten the front-half of the driveshaft. The US Gear solution is around $1,800 and requires a pull-cable for engagement and shortening of the drive-shaft. The GV unit is essentially a compact 2-speed automatic transmission that can be shifted on the fly but doesn't like downshifting). I understand the USG unit can be shifted on the fly up to 35-40 mph but it's like shifting a transmission with no clutch (you have to be smooth and good with the gas pedal). The 4L80E is expensive (total can be $5,000 to $6,000), requires stand-alone electronics, requires a solution for the speedo-cable but is the most driver-friendly of the OD's.
Questions: Are my assumptions correct ($, required installation changes, operation, etc.)? Has anyone had really good or really bad experiences with any of these options? Am I missing a good alternative? Thanks! |
Re: Overdrive Options/Gear Vendor/US Gear/4L80E
700R4 and 200R4. Both will have to be built to withstand the power/torque of a 402, but I would imagine they could be done for about the same price as the USG unit.
I put a 700R4 in my 72 GMC behind a TPI 350 with 3.73 gears, and it was great on the highway. |
motor exploder
I went from a 454/th400 to a TREMEC TKO 5 spd. I have 3.73's.
The 700R4/200R4 might be cheaper though. I've got about $2200 in my setup and it is nice, but not the cheapest option. I really wanted a 5 spd. You would probably be better off using an overdrive automatic. Less chopping/cutting/fab. 5k seems high for a 4L80E conversion, but I've never done one, so I don't know for sure.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
![]() Join Date: Feb 2001
Would it make sense to go back to a 3:08? My truck also came with a 3:08 but now it has a 3:55 (something like that) and I was wondering if it would pay to go back to a 3:08. By the way...I also have a 402BB/400 set up. Good topic
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 09-28-2009 at 02:25 PM. |
![]() Join Date: Nov 2007
700r4 would prolly be the easiest
Eat My Rust
200R4 is the easiest in that it's the same length as the TH350/400, and depending on what your looking for, many say better gearing (as it has similar gearing to the 350/400). The 700R4 has a very short 1st gear which is awesome for towing, and torque. But it's longer and requires a bit of work moving the crossmember and shortening the drive shaft. Both can be found with mechanical speedos, and both can be built strong for pretty cheap.
70CST,
Returning to the 3:08 is not a bad option. I would probably order bearings and seals along with the gear set. I have never set-up a differential but I am pretty good at following directions. Any idea what I would have into the conversion if I did the work myself? How much would the labor be for a pro to do everything? Dan |
