10-15-2008, 06:10 AM | #1 |
Truck Junkie
Suspension Swap
I've read numerous post regarding the swapping the front suspension with just the matter of drilling a few holes and whiz bang there we are new and improved stuff from the 80s....My question is what is the benefit of swapping the cross member if you can just swap out the control arms, spindles and steering gear, leaving the cross member intact...I have no problem doing it i just want to know i'm improving my truck and safety and all that crap...My 70 does need some help. I have all of the suspension from a 90 model suburban to add to my truck... I just want to make sure it will be for the best, better brakes, steering etc..Straight scoop is what i need from all o you "veterans of swap" Thanks guys
10-15-2008, 08:48 AM | #2 |
67-72 parts collector,…
Re: Suspension Swap
I've never understood the benefit of swapping the crossmember itself. I always leave it and swap everything else. Maybe ease of switching everything if you are NOT going to tear it all apart. But I always rebuild everything. (balljoints, bushings etc.) So it has to come apart anyway.
10-15-2008, 09:21 AM | #3 |
Truck Junkie
Re: Suspension Swap
Oh i will be sure to rebuild everything....i'm just curious as to why change the crossmember if the is no need to...thanks
10-15-2008, 11:18 AM | #4 |
Happy to be here
Re: Suspension Swap
There is no real advantage. It's just easier to clean up and install as a unit.
10-15-2008, 12:27 PM | #5 |
Truck Junkie
Re: Suspension Swap
Thanks, I'm fixing to start this project in the next few days and i can use all the help and info from the been there done that folks i can get!
10-15-2008, 12:55 PM | #6 |
Re: Suspension Swap
switching the crossmember allows you to lower the vehicle more. the factory crossmember sits below the frame rails, most aftermarket kits sit the crossmember up in the frame rails thus giving you more travel when lowering, especially with air. Also most kits utilize rack and pinion steering vs the steering box.
10-15-2008, 04:40 PM | #7 |
Re: Suspension Swap
stunna,... I think lo72 is talking about using the 71-87 (and 88-91 'burb) factory style "complete crossmember assembly" to add disc brakes. But you are correct about the aftermarket stuff.
10-16-2008, 10:21 AM | #8 |
Re: Suspension Swap
10-16-2008, 12:19 PM | #9 |
Loading.....
Re: Suspension Swap
I read that the advantage is the shape of the crossmember below the oil pan - it allows you to drop your oil pan without lifting the motor.... not something I've tested tho.
-M7 '69 SWB GMC 5.7 EFI ‘69 C/10 SWB patina survivor ‘71 GMC K20 '72 K5 1-ton gear 468BB ‘86 K30 GMC High Sierra C&C Single Cab '96 SWB Single Cab 5.7 ‘99 SWB Z71 Single Cab '00 SWB Single Cab 5.3 '01 K2500 Yukon Safari 6.0 ‘06 2500HD Single Cab C&C Duramax 4x4 '08 1500 crew '11 2500HD Single Cab Duramax 4x4 |
10-16-2008, 10:02 AM | #10 |
Texas Big Wig
Re: Suspension Swap
Yep, no reason to if you are gonna disassemble it anyway
In my case, I had a rebuilt front end & didnt want to tear it apart to swap it out |
10-16-2008, 01:17 PM | #11 |
Re: Suspension Swap
I unbolted one set of upper and lower A-arms and bolted them to the existing crossmember ... I was using drop spindles so I didn't need all the other stuff.
