11-05-2002, 09:12 AM | #1 |
Heater/Defroster Problem
Hello fellas,
Hope someone can help. Now that it's gotten cold here, the defrost in the 84 K20 works good, blows good and is warm not hot. The heater blows good, but is nowhere near hot, in fact, it is cool. Anyone have any ideas? I thought you only replaced the heater core when it leaked. Do I need a new one? Thanks in advance. Jay
84 Chevy K20 99 Chevy Big Block Burb |
11-05-2002, 09:18 AM | #2 |
Just a couple of things to check:
- what temperature thermostat do you have, I'd suggest running the stock temp. - it's possible that your cooling system needs a flush, you can always just flush the heater core if you want, disconnect the heater hoses and hook a garden hose to it. Ken |
11-05-2002, 10:30 AM | #3 |
She runs 180 degrees all the time, 80 degree summer
and 10 degree winter. Doesn't get any better with the plow on it either. Probably will do a cooling flush. Don't have any idea what condition that's in. Jay
11-05-2002, 07:10 PM | #4 |
Shadetree Mechanic
You may want to check the cab controls and make sure the diverter doors in the duct work are moving where they should.
There is one door that controls where the air goes, i.e. floor, vents, defrost. There is a second one that controls the amount of air coming through the heater core. This one may no be moving all the way to heat. Of course this needs to be checked in addition to the heater core circulation.
Dave M. (Hacksaw) 86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance 89 GMC S-15 Extended Cab 4x4, 4.3L, FI 98 K1500 Xcab, 5.7L, 3.43 Gov-Lok |
11-05-2002, 09:35 PM | #5 |
Do a quick test...
Warm the engine up to full temp. Next you'll need to feel both heater hoses. Tell me if: Inlet hose is hot / outlet hose is hot Inlet hose is hot / outlet hose is cold inlet hose is cold / outlet hose is cold. From this info I'll be able to let you know where the problem is. |
11-05-2002, 10:29 PM | #6 |
Robert Olson Transport
cool heat
i would check the doors first unless its been a real long time since you flushed the coolant; i know that on my truck the cable rusted and it locked out and i had no heat
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
11-06-2002, 07:27 AM | #7 |
Doors all work fine, fixed those when I had the dash apart
to fix the headlight wiring disaster. I will check the in/out lines tonight after my ride home from work. Thanks will let you know what I find out. Jay
11-06-2002, 10:35 AM | #8 |
Jay,
I'll assume that you have a 180 degree thermostat. I have previously ran a 180 degree thermostat and this year changed back to the stock 195. I don't drive my truck in the winter but I really noticed the difference in the amount of heat that the heater put out this fall. I also noticed an increase in gas mileage. So do you have enough snow for the MXZ600 yet? We've got a few inches on the ground. Ken |
11-06-2002, 11:49 AM | #9 |
I do need to change the water neck, so I can change the
thermostat to see if that helps after I flush the coolant system. Can I tell what thermostat I have visually, or should I just spend the few dollars and buy a new one? Not enough snow for sleds yet, but we have the annual grass drags coming up Saturday. Can't wait to ride it again, have 3 miles on in the grass already just tuning. Thanks, Jay
11-06-2002, 12:06 PM | #10 |
The temperature is stamped on it but I would purchase a new one anyway.
Ken |
