07-18-2011, 12:04 PM | #1 |
BLACK SATIN
temp gauge after installing V8
We just put in a 1985 305 V8 in my 67 3/4 ton that had a 250 in it. The temp gauge goes from below the lowest mark to just over the lowest mark at operating temperature. I bought a huge aluminum radiator for it & a friend checked the temp with his no touch temp meter & got only around 164 degrees. How can I get the temp to go in the operating range on the gauge? I don't know what t-stat is in the newer motor.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci |
07-18-2011, 12:52 PM | #2 |
Re: temp gauge after installing V8
what degree of thermostat is in it now?
07-18-2011, 03:14 PM | #3 |
BLACK SATIN
I don't know which t-stat is in it now.
07-18-2011, 04:09 PM | #4 |
Junior Member
If it were me I would put a 180 degree thermostat in it and then see what the temperature gage reads.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-16-2011, 09:11 AM | #5 |
BLACK SATIN
It had a 195 degree t-stat in it. I put in a 180 degree t-stat & it hasn't changed. Somewhere I heard something about the ground on the motor?
09-16-2011, 10:36 AM | #6 |
i had the same problem. replaced the temperature sending unit with a better one i purchased thru Eckler's. Problem solved
09-16-2011, 10:38 AM | #7 | |
PITbut
My guage was reading normal at freeway speeds then would peg hot at idle. My guage spring in my old ass guage just wasnt working correctly... As for grounds. You should have a few on the truck.. Frame to engine, frame to cab. Good grounds are a must.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
09-16-2011, 10:48 AM | #8 |
I've tried many new temp senders and have yet to find one that works correctly with factory gauges, in more than a few trucks. My Blazer reads as yours does now.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
09-16-2011, 10:56 AM | #9 |
BLACK SATIN
The temp gauge worked fine with the 6 cyl motor in it. I did replace the sender & no change.
09-16-2011, 11:05 AM | #10 |
i was told the temperature send units you get thru the local parts places are junk. the one i got thru ecklers was like 25 buck i think. but once installed it works great.
09-16-2011, 11:49 AM | #11 |
I'm having the same problem now. I see one post for gauge and another for sending unit. All that's left is the wiring haha. Please post what you did to fix. Thanks
She's gonna go, or she's gonna blow |
09-16-2011, 01:19 PM | #12 |
PITbut
This is funny cause i went through this EXACT thing. Used different senders, aftermarket and expensive. Nothing worked. My guage had just become to week.. So when it was at the correct ohms for 190 degrees it would go all the way to hot.
09-16-2011, 12:05 PM | #13 |
I am a Referee of life.
Try the sending unit out of the 6.It should go back to reading like it alweays did.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-16-2011, 12:48 PM | #14 |
Ok. Figured out a good indicator. The temp gauge works off resistance value of sender unit. To see if it's gauge or sender. Just ground the sender unit or wire to it and turn on key. If gauge pegs to hot then your sender is bad.
Now granted I'm still troubleshooting mine, so I'm not leaving out possibility that low coolant or air or another such factor is in effect. My gauge pegged so now to figure out range of sender unit both cold and hot I'll then read it cold and throughout warm up till run and read ohms on sender unit. I think it goes from 220 ohms cold to 68 ohms at middle of gauge. Hope this helps Posted via Mobile Device
09-16-2011, 01:09 PM | #15 |
BLACK SATIN
I was going to try the old sender, but it has different size threads.
09-16-2011, 01:10 PM | #16 | |
PITbut
Mine did. Change the guage out and be done... Quick/ easy/ more accurate.
