12-20-2010, 10:48 AM | #1 |
Timing issue
Just finished installing a 355 in my project. I timed it at 10 degrees btdc and it ran terrible. Timed it the old fashioned way, advancing until it pinged under a load and then backed it off a little. It ran fine but when i checked it with a light it was at 18 degrees btdc. It has a cloyes chain set. If i used the wrong keyway that would account for 4 degrees. It has a comp cams 268 xe cam, performer rpm heads and intake, dui dist, a 600 cfm carb, hedders, and 10.25 to 1 comp. Should i pull it apart to check the position of the bottom gear or leave it alone? It also has a fluidamper balancer that is new.
12-20-2010, 11:40 AM | #2 |
Re: Timing issue
Now i really feel stupid. After talking to the folks at cloyes they told me advancing or retarding the cam by using the different keyways on the crank gear changes the rpm range where the power band is, it has nothing to do with the timing marks on the harmonic balancer. I was thinking if i used the 4 degree advance keyway it would affect the timing by four degrees at the balancer. Back to square one.
12-20-2010, 11:53 AM | #3 |
Re: Timing issue
18 is not outrageous but keep in mind these trucks are heavy and you will be detonating even though you can't here it. Most guy's with builds like yours end up running about 12-16 and 30-34 at 2500 RPMs. With vacuum that would be about 50 all in at 2500 RPM. What is your timing with the vacuum applied?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-20-2010, 12:05 PM | #4 |
Re: Timing issue
I'll get back to you with more specifics another day. My truck is in my son in laws garage now, about a 45 minute drive away. It's heated and the outside temp is in the upper 20's.
12-20-2010, 03:26 PM | #5 |
Re: Timing issue
You might also want to verify TDC using a piston stop in the #1 cyl.
12-20-2010, 08:28 PM | #6 | ||
Re: Timing issue
This may sound stupid, but what does DUI say to run it at? I have never used one of their distributors, but the website makes it look like that are calibrated individually...per provided specs. Is this the case? Did you spec this unit for this engine?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
12-20-2010, 08:41 PM | #7 |
Got big-block?
Re: Timing issue
Here's some things you might try:
How to Set the Timing for Optimum Performance: When you think about it, setting the timing at idle speed makes no sense at all: You don't operate your car at idle, and timing changes as the rpm changes. Fact is, the timing spec at idle speed is provided as a simple way for most people to set the timing, and is not a good procedure for optimum performance. Small block Chevys (and most other GM performance V8 engines) perform best when the total timing (full centrifugal advance plus the initial timing setting with vacuum advance disconnected) is all in by 2,500 - 2,800 rpm and is set to 36-38 degrees. If you have an adjustable timing light, this is very easy to check. If you don't, you need to scribe a 36-degree mark on your harmonic balancer. Here's how: Measure the circumference of your harmonic balancer using a sewing tape measure (or other flexible tape measure). Get it as accurate as you can. Take this measurement and divide by 10. The number you get is the distance to 36 degrees. Measure this distance CLOCKWISE from your existing harmonic balancer timing mark and place a clear mark on the balancer. Remove your distributor cap and rotor. Remove the 2 centrifugal advance springs. Install the rotor and the cap (without the springs). Disconnect the vacuum advance. Start the engine. It may kick back a little due to the advance coming in immediately without the springs. If you're using an adjustable timing light, set the light to 36 degrees advanced. Now rev the engine just a little while observing the timing marks with the light. It shouldn't take much rpm to peg out the advance without the springs installed. With an adjustable light set at 36 degrees, align the stock timing marks with 0 when the timing is pegged out. With the non-adjustable light, align your new 36-degree mark with 0. Rev the engine a little to make sure the timing will not advance any further. Shut it down. Pop the cap and rotor and re-install the springs. Put everything back together, but leave the vacuum disconnected. Start it up. For future reference, make a note of the timing setting at idle. This is your new curb idle timing spec. Now give the engine a few quick rev's past 3,000 rpm and verify that the full timing (36 degrees) is coming in. If it's not, you need to change to a softer set of springs until you get full 36- degree advance before 3000 rpm. (NOTE: A stock set of springs will usually not allow full centrifugal advance to come in before redline rpm. If you have stock springs installed, don't rev the engine beyond its limits to try to force full advance in.) Shut it down and hook up the vacuum. Now do a road test. The 36-degree 2500 rpm advance curve is optimum for performance, but may require premium fuel. Lug the car around, and punch the throttle at low rpm while listening for detonation (.engine knock.). If you're getting any audible knock, you MUST retard the timing. Retard the timing in 2-degree increments until engine knock stops. Engine knock will seriously damage engine components if not corrected. If you get no knock, you may see slightly improved performance at 38 degrees total timing. This is particularly true if you're running at high altitude. If you have no engine knock under acceleration, but the car "chugs" or jerks at cruising speed (light throttle application), you are getting too much vacuum advance on top of the mechanical advance. You may need to change out the vacuum advance diaphragm with an adjustable unit available from aftermarket sources. Adjust these units so that you get the most vacuum advance possible without any "chugging" or jerking at cruise speed. Your timing is now set for best possible performance. Make note of the new setting, and use this for your future tune-up work.
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
12-20-2010, 09:10 PM | #8 |
Re: Timing issue
Subscribed!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-20-2010, 03:34 PM | #9 |
Re: Timing issue
I would try it around 12-14 and see how she runs...
If you dont HEAR any ping at 18, I would think 12-14 would be pretty safe...
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
12-21-2010, 05:21 PM | #10 |
Big Red - Now its a SWB!
Re: Timing issue
All good advice, just wanted to add that I have a similar setup to you and I run premium fuel and have my initial timing set at 16* btdc and have no pinging and it runs good. I have yet to run through the full procedure outlined above, but I'm gonna do it soon.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
