Old 10-14-2023, 02:02 PM   #1
Hideintire
Hideintire's Avatar
Centerlink question
Hello,
I converted to 73-87 crossmember and components, but when I use the 73-87 centerlink the idler and pittman are not parallel! When I compare the '71 with '73 up, the 73 up is 1/2" shorter. Is the idler arm frame mount different between '71 and '73 up?
Truck is a '71 C10. Thanks for your input.
Hideintire is offline   Reply With Quote
Old 10-16-2023, 12:53 PM   #2
Re: Centerlink question
The pittman arm is different between power and nonpower units. I ithink idler is the same. When i did my swP i usednew pittman and idler from the 84 i usde partsfrom.
Old 10-16-2023, 03:36 PM   #3
Hideintire
Hideintire's Avatar
Thanks for the reply.
I got a square body idler arm bracket today. There is a big difference in the two. Wish I'd known ahead of time so I could have gotten the bracket when I got the centerlink.
Anyway, if anyone else does the upgrade to '73-'87 A-arms and steering...you must use the centerlink and the idler arm bracket.
Old 10-20-2023, 12:57 AM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
There was a change in design on the idler in 83. They went to a smaller stud on one side. 82 and down used the same idler for many years. I found that out when I put a square crossmember on my 68 stepper.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
