Old 09-22-2014, 11:11 AM   #1
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Moody Blues
I should of called my truck Moody Blues instead of Marathon Blue, I had sprung a oil leak on the top back side of the engine, I tighten the Distributer, and the oil sending unit not leaking,Not the valve covers,its only on the passenger side top and running down the back side of transmission passenger side, could it be the rear intake gasket, I ran the engine off and on without the body on it for months and never had any leaks, but low and behold i put the body on and finish the truck and within a month i get a leak. And its not a small leak either. I tried using a small mirror to see on the back but the engine sit really close to the fire wall, I really did not want to pull the top of the engine but it looks like i do not have a choice.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 09-22-2014, 11:17 AM   #2
Saclandman
Saclandman's Avatar
Re: Moody Blues
Nice 4X4!
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 09-22-2014, 04:00 PM   #3
Mr Chevorlet
Rusty Nuts
Re: Moody Blues
Originally Posted by Saclandman View Post
Nice 4X4!
Thanks saclanman
Larry
Mr Chevrolet
Old 09-22-2014, 11:20 AM   #4
70shortfleet
70shortfleet's Avatar
Re: Moody Blues
If your sure it is not the valve cover and the distributor gasket, it is more than likely the intake manifold leaking
70shortfleet is offline   Reply With Quote
Old 09-22-2014, 11:30 AM   #5
leftybass209
leftybass209's Avatar
Re: Moody Blues
You've already got the process of elimination going! You can always spray some degreaser back there and clean it as good as possible before you go pulling parts but, I think you already know where it's leaking from Best of luck!
leftybass209 is offline   Reply With Quote
Old 09-22-2014, 11:37 AM   #6
Mr Chevorlet
Rusty Nuts
Re: Moody Blues
The engine is spotless and the oil is fresh and clean so that makes it really hard to see oil coming out, I tried feeling back there to feel oil but its close quarters, But i will change valve cover gaskets first, then if that dont do it i will pull the intake, Thanks guys
Larry
Mr Chevrolet
Old 09-22-2014, 11:41 AM   #7
sboris
sboris's Avatar
Re: Moody Blues
How frustrating! Good luck Larry, hope that does it.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 09-22-2014, 11:58 AM   #8
Grumpy old man
Grumpy old man's Avatar
Re: Moody Blues
Clean off any oil you can see and once the area is dry dust it with baby powder and then run the engine the powder will lead you directly to the leak (aircraft mechanics use this trick everyday to find hidden leaks and avoid tear downs)When done just hose off the remaining powder .
Old 09-22-2014, 03:59 PM   #9
Mr Chevorlet
Rusty Nuts
Re: Moody Blues
Thanks grumpy and no1udknow,i will try that
Larry
Mr Chevrolet
Old 09-22-2014, 04:03 PM   #10
Mr Chevorlet
Rusty Nuts
Re: Moody Blues
Yes sboris it is frustraiting.
Larry
Mr Chevrolet
Old 09-22-2014, 01:12 PM   #11
no1udknow
no1udknow's Avatar
Re: Moody Blues
I've got a little trick for you, clean the area really well using brake cleaner (because ot removes the oil and makes the surface really dry) go to your local walmart or pharmacy store and pick up a couple cans of Tinactin spray foot powder. It is usually in a white can with a maroon/burgundy lid. Spray the hell out of the area the powder will dry white. Run the engine for a few minutes and look back there again with the mirror. The area where the leak is will turn brown and is easy to spot against the white powder. This is a trick we use in motorcycle shops to find small oil leaks, works great as long as you get the surface clean ahead of time
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 09-22-2014, 01:30 PM   #12
Grumpy old man
Re: Moody Blues
That's what I said but baby powder is A LOT less expensive than Tinactin. And smells better
Old 09-22-2014, 01:32 PM   #13
no1udknow
no1udknow's Avatar
Re: Moody Blues
Yah, I read that right after I completed my post. I like the tinactin because it sprays on, but yah from a cost point baby powder is cheaper
Built not bought!
Old 09-23-2014, 12:50 AM   #14
GuyO
GuyO's Avatar
Re: Moody Blues
I have thought using red food coloring added to the crankcase? I can't see how it could hurt anything and would leave a blood trail. Or maybe green because red might look too much like ATF! my .02. G.
GuyO is offline   Reply With Quote
