Old 07-21-2012, 03:16 PM   #1
CEE1NG_RED
Is it necessary?
Does the trans oil have to be drained out before taking out the speedometer cable and trans oil cooling lines? Seems the leak is coming from the rubber hose of the cooling line and speedo cable. Can it be done or leaks will occur if not drained?
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 07-21-2012, 03:21 PM   #2
Roninwolf
Roninwolf's Avatar
Re: Is it necessary?
It's not necessary to drain. The speedo has a o-ring and you need to replace the trans with steel lines. But you can use rubber but will leak over time.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 07-21-2012, 04:57 PM   #3
CEE1NG_RED
Will a lot of oil come out when I disconnect these lines?
Old 07-21-2012, 05:01 PM   #4
Dunenutt
Newbee
Dunenutt's Avatar
Should be just what is left in the lines.
Dunenutt is offline   Reply With Quote
Old 07-21-2012, 05:29 PM   #5
CEE1NG_RED
The speedometer cable is stuck onto the piece that holds the purple plastic gear. I had tries to unscrew it from it but no avail. Can I use PBlaster? So I can remove/screw it out from the speedo cable and change the inner seal?
Old 07-21-2012, 05:57 PM   #6
Roninwolf
Roninwolf's Avatar
usually u take the speedo cable loose from gear before u take it out of the trans. losen the cable nut with channel locks just dont squeeze to hard then scew cable nut off and pull cable out of gear and housing then take out bolt that holds gear housing in trans and pull it out.
My build thread
72 Cheyenne Super
Old 07-21-2012, 06:45 PM   #7
ole dollor
ole dollor's Avatar
i have seen this before.....i think its called texing.....i r rt
lol
ole dollor is offline   Reply With Quote
