01-24-2012, 02:33 PM | #1 |
78K & 79C Jimmys
Steering coupler or Rag joint
I replaced mine last fall
when i ordered the part at first it seemed there was only one used Dorman 31011 this puts my steering wheel out 180 or upside down called and ordered the 31015.....wrong size called dorman was told "they have never heard of this upside down before" asked at a GM dealer "someone may have changed something" before i turn my wheel around,is this normal?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-24-2012, 07:01 PM | #2 |
Re: Steering coupler or Rag joint
When I swamped columns on my 79 it did the same thing. My solution was to drill out the plastic from the two holes on the steering shaft and pull the shaft apart. Once this was done I flipped the shaft over and reinstalled it.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-26-2012, 01:01 AM | #3 |
I ran into this exact same problem. I happened to have discovered earlier during an ignition switch replacement that the PO had actually swapped the original '78 column for a '77 and I assumed that is what caused it. All I did was center the wheels, take the bottom of the column off the streering gearbox, and slid it up so the steering column could turn freely. Then I the centered the steering wheel and pushed the column back on the box. Took a couple of tries to get it centered correctly.
Posted via Mobile Device |
01-26-2012, 08:14 AM | #4 | |
78K & 79C Jimmys
01-26-2012, 11:58 AM | #5 |
If it is the same as mine, it is only keyed on the side that connects the coupler to the shaft: the other side of the coupler (the part that connects to the gearbox) just slips onto the splined shaft of the gearbox. In that first pic you have there you can see a big fat nut on the left side of the coupler right next to where it connects to the gearbox. I just loosened that, banged the crap out of the shaft to break loose the rust, slid it off and turned the wheel. So basically, the WHOLE joint is still connected to the shaft (the new shiny bit you just put on and the ugly old rust side too); you rotate the whole assembly and then join it back to the gearbox.
01-26-2012, 06:36 PM | #6 |
78K & 79C Jimmys
my gearbox is keyd with a flat side that only fits one way
and then are the two different sized bolts thought i took more pics...nope
01-27-2012, 03:29 AM | #7 |
Forgive my ignorance but what exactly is the rag joint for and why would it be a good idea to replace it?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-27-2012, 03:46 AM | #8 |
it allows for flex between the steering shaft and box.. a really really low tech u joint really.
they become worn out and loose..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
01-27-2012, 03:51 AM | #9 | |
01-27-2012, 04:08 AM | #10 |
do you have actual slop? tighten up your box too.
01-27-2012, 08:04 AM | #11 |
78K & 79C Jimmys
It sure helped to make mine feel better
driving along you could sorta wiggle the wheel left to right looking under the hood the box didn't turn till the "pin " touched the new one dosn't touch,i'd leave it rubber alumi don't flex gee guess I could say don't 86 the rubber !lol
01-27-2012, 08:42 AM | #12 |
You can also swap in the steering shaft out of a Jeep Cherokee, XJ shaft swap. These have U-joints at both ends, and pretty much bolt in.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
03-04-2012, 05:32 PM | #13 |
Did ya figure this one out? I just swapped mine out, same exact part number and all. Had to flip my steering wheel upside down to get it back together. Now, it is pulling to the right some. Ugh.
84 SWB C10 Project |
03-04-2012, 05:59 PM | #14 |
78K & 79C Jimmys
No it's still upside down ,but drives fine,
I'm living with it, cause I' m going tilt, deal with it then Only prob is I get caught flashing sometimes lol Havn't seen any complaints , so I duno what ,but see if the tilt fix , fixes it Posted via Mobile Device
03-05-2012, 12:35 AM | #15 |
Yeah, mine seems to work fine.. I have a tilt column stock too.. same problem as you! I tried tearing apart the old joint to just put a new pad in it. No such luck so far.
03-05-2012, 12:53 AM | #16 |
Does your colapsable shaft unbolt from the column up by the firewall?
If so you can unbolt it there and spin the wheel 180 then bolt it back together. It should fit either way... Posted via Mobile Device
CHEVY ONLY |
03-05-2012, 05:34 PM | #17 |
78K & 79C Jimmys
thanks gona check that out
03-05-2012, 01:46 AM | #18 |
Joe, you are my hero! I went and took a look, and sure enough there was a bolt! It took some serious tugging to get it off, and putting back on, but my steering wheel is back to normal! No modifications to the backwards rag joint needed!
03-05-2012, 02:09 AM | #19 |
Glad I could help
CHEVY ONLY |
03-05-2012, 03:03 AM | #20 |
You guys think that the rag joint I necessary? I know they are a cheap kind of u-joint/ vibration dampner. It seems lik the column to the box is very straight. I may pull the rubber part on mine and mill a aluminum donut for a replacement
03-05-2012, 12:10 PM | #21 | |
Desert |
03-05-2012, 07:33 AM | #22 |
I would definitely keep the rubber. It allows for a little bit of flex when needed, where aluminum won't.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
03-05-2012, 11:22 AM | #23 |
Does the J**P steering shaft work for these trucks? I know it made a DEFINITE difference in my GN... And it's a LOT less espensive versus making your own (have one with pto outputs on another rig...)
riding... just riding....... |
03-05-2012, 07:38 PM | #24 |
Moderator
You mean the XJ Cherokee column? Yes it fits. It cleans up a lot of slop.
07-17-2019, 01:36 PM | #25 |
I found this thread while researching options so I'm dusting this one off....
I lost the rag joint on my Dually Sunday night. It was only a few years old as I replaced it when I re-did the suspension on the truck. Now, it failed under extreme circumstances as I needed to straighten the front wheels but couldn't start the truck @ the time. I tugged on the wheel, the wheels straightened some but I needed a little more. Tugged on it again & snap. Rag joint coupler rubber ripped apart. I put it back together w/another replacement piece but it leaves me lacking confidence in a 'worst-case' scenario. I looked into the Cherokee set-ups but I'm not doing the wrecking yard crawl for 20+ year old wearable parts. I looked up replacement stuff but online local auto parts don't break the models down into Cherokee XJ etc etc etc..... The replacement part that pops up on Oreillys doesn't seem to match my set-up either (3/4-30 spline X 3/4 DD). Anyone found newer/better options that also work??
