12-18-2005, 11:53 AM | #1 |
mini spool
anyone running one of these on the streets?
71 chevy lwb w/ 350,750 holley 4150,edelbrock performer rpm,full 2 1/2 exhaust exit out side,6-8 drop,rally wheels.-SOLD 74 Chevy nova-355 with a little nitrous 78 GMC Jimmy 4x4-Factory 400 and all stock. |
12-18-2005, 12:00 PM | #2 |
Re: mini spool
not suited for the street a waste of money
12-18-2005, 12:05 PM | #3 |
Re: mini spool
definately a bad idea on the street.if you want a posi get a clutch style like eaton or similar and it will allow you to safely make turns
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-18-2005, 12:10 PM | #4 |
Re: mini spool
Ever ride a go-cart?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
12-18-2005, 08:43 PM | #5 | |
Fabricate till you "puke"
Re: mini spool
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-18-2005, 12:19 PM | #6 |
PROJECT 7DEUCE
Re: mini spool
I got one in my toyota but its not a daily driver and with the rear end locked up it is down right scary to drive in the rain.. Bad idea for sure..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-18-2005, 04:18 PM | #7 |
Re: mini spool
If you need to turn corners its not a good idea.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
12-18-2005, 06:48 PM | #8 |
Re: mini spool
I had a friend install and remove one once. NOT safe for a driver.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
12-18-2005, 07:16 PM | #9 |
71 GMC 454/TH400
Re: mini spool
I ran one on the street in a lifted 4x4 it was okay, exept in the rain, or on tight u-turns, other than than that it would just drag one of the tires in th turns not bad, but if it was primarily a street driven truck I'd buy a posi, or one of the lockers the replace the spider gears. On the 67-72 chevy trucks if you add one extra shim be hind the spider gears it will act like a limited slipm I have done this many times.
