01-04-2006, 01:09 AM | #1 |
Question about door panels.
I have a question about door panels I have a 72 c10. When I look for door panels all i get is crappy looking panels. the ones i like says 67 -71 heres the link http://www.brothersonlinestore.com/p...number=DPR6771 will they not fit or did they just not come in that truck.
01-04-2006, 01:14 AM | #2 |
Re: Question about door panels.
the 67-71 pannels will not fasten to the 72 doors as there are no nuts welded into the door like the 67-71 doors. You also have longer window and door cranks in you 72. What is it that your looking to buy ? New Pannels for the 72's are avaible.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-04-2006, 01:15 AM | #3 |
I should add just for th eheck of it if you have a 67-71 an would like to use 72 pannels you need 72 window crank and door latch's and you can drill the hole that will allow you to use the 72 pannels on the older door.
