05-11-2005, 09:18 AM | #1 |
Need help hooking up quadrajet..
What hoses go where on this thing? Currently I run an edelbrock performer and have three hoses hooked up to it. Power brake, PCV, and distributor. The distributor is an HEI. This quadrajet has about a million hook ups. What goes where?
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 05-11-2005 at 10:12 AM. |
05-11-2005, 09:45 AM | #2 |
The one on the front I pluged the big brake one on the back I pluged.
The small one on the left I put on the dizzy. And the big one on the bottom front I put on the PVC. Hope this helps.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
05-11-2005, 11:02 AM | #3 |
Looking at front of carb: upper right,ported for dizzy; lower right, plug (for evap); middle bottom, PCV; lower left, plug (for EGR); upper left, connect to choke pull-off.
Large threaded one in rear for brake booster, any others not showing plug off.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
05-11-2005, 07:17 PM | #4 |
I don't run a choke on my truck so where would I hook up the one to the farthest left (on the choke piece)
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 05-11-2005 at 07:18 PM. |
05-11-2005, 07:50 PM | #5 |
20' Daredevil (Ret)
Mine isn't exactly like your pic, but.... in your pic, the one on the far lower right of the carb body (not the base plate) goes to my dizzy. Next to the left (large one left of center, in the base plate) goes to PCV valve. Big one in the rear is brake booster. Then it gets a bit different.
Above my PCV port and at a downward angle goes to the choke pulloff. Behind the choke and sticking out to the side is one for the stock air cleaner. Not sure which of your remaining 2 ports (on the left) is for what.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
05-11-2005, 08:31 PM | #6 |
Where does this one hook up to?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-12-2005, 07:22 AM | #7 |
The one on the far left connects to the choke stove in the manifold. Not a vacume port but draws air through the stove to warm the choke coil and open the choke. If you don't use this plug it and adjust the choke coil so the choke plate stays open at all times.
05-28-2005, 10:00 AM | #8 |
Got all of the vac lines hooked up except the tranny modulator, which line does it go onto? There are two on the back of the carb, not counting the power brake booster line.
Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside) 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
