10-17-2005, 10:33 AM | #1 |
700R4 column P R N OD 3 2 1 indicator
I switched to a 700R4 from TH350. Does any know what gear shift lens work with our non-tilt columns that has the P R N OD 3 2 1?
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
10-17-2005, 10:48 AM | #2 |
chevy truck fan
Re: 700R4 column P R N OD 3 2 1 indicator
frank,
i have just finished doing the same thing. i too am looking for the 4 sp. indicator. i think i have found one in my rb's catalog. for $20. they are local here in the phx. area. it shows 1 2 3 d . not the od, but this will work for me. i think they have a web site that you can check out. hope this helps. rodstored-72 |
10-17-2005, 11:42 AM | #3 |
truckandcarshop dot com has some. I don't know if they work with non-tilt though. You can only order a catalog online, no ordering. They may have a tech line though.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster Last edited by sdkid; 10-17-2005 at 11:42 AM. |
10-17-2005, 01:46 PM | #4 |
There is a board member that sells them. His name is onebad or badone or something like that. He is in Arizona or Nevada I think.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-17-2005, 02:25 PM | #5 |
I wonder if he was the guy selling them on Ebay a while back. Maybe he will respond to this tread?
10-17-2005, 04:15 PM | #6 |
Vintage Evil
ricks truck parts was selling them on ebay a while back
10-17-2005, 10:17 PM | #7 |
Car O'Holic
How was the swap? Was it easy? What all did it take? Where did you get the transmition? How is it now? We need to have an AusTex meet so I can see all of the local board members rides and we can all swap ideas and see eachothers trucks.
10-18-2005, 05:23 PM | #8 | |
First When I bought the truck way back when it had the V8 in 6 cylinder position. This moves the engine about 3.5 inches back. With a short tail TH350 and a crossmember from god knows what that was bolted on under the frame. So I gathered the correct V8 frame mounts and crossmember. Bought a used 1988 700R4 from a TPI car with 88K miles. Then pulled the motor and tranny and installed the V8 frame mounts. Attached the 700R4 to the motor and installed with correct crossmember. Because I used the V8 frame mounts I did not have to cut the drive shaft so now the motor sits 3 inchs more forward. I only had to drill 2 holes in the frame for the crossmember to bolt up. If you have a long shaft TH350 (9 inch) I dont think you have to cut the drive shaft. Just move the crossmember back. The above went great. Then The 700R4 lost OD then shortly there after reverse. Pulled the tranny for a rebuild. The tranny guy said the trans had a mix of parts. He rebuilt it. I installed it again. It did shift good but the tranny guy messed something up in the valve body. So the tranny guy built a new 700R4 and converter and I gave him my old set up back. Installed for the 3rd time. So now it shifts great. Has HD parts in with the corvette servos and 1800-stall converter. Chirps the tires in second. I have the converter lock up/out controlled with a vacuum switch and with brake switch. I still have to install the speed controller that will only allow converter lock-up above 30 mph. The converter locks up in 2nd 3rd and 4th when the engine vacuum is high or if i'm not applying the brakes. Results 70 mph 1800RPM 18.5 mpg at 70 with ac on. Getting 16.5 mpg on work loop. I was down at 12 mpg for awhile. The low first gear is great too.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas Last edited by Frank_Zeller; 10-18-2005 at 05:26 PM. |
10-18-2005, 05:50 PM | #9 | |
Car O'Holic
DAM I get 9-10 in mine and at like 70mph im at like 3700rpm. I really need to do this to help on the gas. |
10-20-2005, 02:33 PM | #10 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
10-18-2005, 08:56 AM | #11 |
keep this one up top I need one too
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-18-2005, 09:14 AM | #12 |
I think gonebad2 is the one that had them, but not positive.
10-18-2005, 10:34 AM | #13 |
chevy truck fan
frank,
if you find what you like let us know where you get it, maybe some of us too will like it... thanks! nice truck in the avatar!! |
10-18-2005, 12:27 PM | #14 |
Dork For Days
I want one too!
10-20-2005, 02:40 PM | #15 |
3.08's and 28 inch tire. 70 series tires.
Engine specs. 1995 GM 305 crate motor with Edelbrock SP2P intake, 1976 800CFM BOP Q-jet with 2 inch 4 hole spacer, 1 5/8 full length headers, recurved HEI with MSD6A. Has thermo fan clutch. 195 F thermostat. Set up for lowend torque and to run on 89 octane. Truck is lowered.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas Last edited by Frank_Zeller; 10-20-2005 at 03:14 PM. |
10-20-2005, 07:06 PM | #16 | |
Dork For Days
I was having trouble with 93 octane knocking on me in my "toy" car and I went from 180* to 160*. Problem solved! I know this is a little extreme on the temp, but the engine seems to like it and I don't notice any other ill effects. It's certainly not computer controlled, so no worries there.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
10-20-2005, 10:04 PM | #17 |
Frank, Check with Shiftworks or Classic Industries. I think both have the OD shift plates. I have one for my convertible that also converts the gates on the stirrup shifter. Nice to see you around! Ever once in awhile I see your truck on 183. One of the drawbacks of a late model truck is nobody notices you!
10-20-2005, 10:23 PM | #18 |
Merciless Butcher
I was the one selling them. I sell them on ebay and they bring a stupid amount of money for a piece of plastic. They are only available for tilt columns right now. I'm going to contact they guy that makes them and see if it's possible to have some made for non-tilt columns. When I talk to him, I'll get some for tilt columns. I sell them to board members for $10.00 plus shipping. If they guy can't make the ones for non-tilt columns, the company my wife works for can....Maybe I'll ask her to see what she can do.
Your Bought And Sold....I Got Your Soul! Last edited by gonebad2; 10-20-2005 at 10:24 PM. |
10-20-2005, 10:40 PM | #19 | |
Where's my beer?
Frank_Zeller sorry to hijack your thread.
Paul How do you make the invisible, visible?.........You take it away. |
10-21-2005, 08:51 AM | #20 |
:tj:
PM also sent, I hope you have a bunch... well I just need one Dave
10-21-2005, 11:01 AM | #21 |
Mike,
I seen your truck one Craig's list. I already checked with Shiftworks and their lens is to short. The local First Gen Firebird club has been meeting at the Home Depot on 1431 and pamer. Some really nice cars and trucks come out. Saturdays around 7:00PM Gonebad2. Put me in line for on too.
10-21-2005, 11:32 PM | #22 |
Merciless Butcher
I plan on ordering some tomorrow.....When I get em, I'll post them on the parts board....Should have them in about a week.
Your Bought And Sold....I Got Your Soul! |
10-22-2005, 10:02 PM | #23 |
Gonebad2 put me down for one also, right now I do not have a tilt installed. I have a tilt that needs to be rebuilt so I could use one of each.
