Welder's warning...
Hello everyone! I am sure that you are having a great day! I just came across this article while doing some research on my Cummins swap for my c/10. I am sure that most of you know this already, but I found it very interesting - this guy was almost killed by a small mistake during welding. Check it out:
http://www.brewracingframes.com/id75.htm Merry Christmas and Happy New Year!
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
Re: Welder's warning...
thanks man i will have to remember this...i am a welder & have used this before ,,,,never again
_____________________________________ 66 C10 shortbed stepside KEEPER 66 C10 longbed stepside SOLD 69 C10 shortbed stepside SOLD 71 C10 custom deluxe long fleetside SOLD _____________________________________ |
#3 | |
Thanks for the article, I did not know that! The first time I ever welded on some galvanized metal it gave me a terrible headache. A navy buddy of mine told me that welding or cutting on galvanized metal could produce phosgene gas. He said that's what they used in WWI, aka, mustard gas. I used a respirator the few times after that and have since decided not to weld galvanized material.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
#5 | |
...And the "Mustard Gas" that was used in WWI as an 'anti-personel weapon' was a mix of Ammonia and Chlorine/Chlorides with another chemical or two added for dispersment and 'stick'. (It was called "Mustard Gas" because the concentrated ammonia and chlonine powders when mixed, were like the color of "Mustard". This was mostly used during the winters and rainy seasons so that when it thawed out on a soldier's clothes later in the trenches or mixed with the water in the air, it worked faster as a weapon taking out more people.) When clorine gas mixes with water in the body it become a form of Hydrochloric acid, mix this with Ammonia and the acid compound becomes very lethal, very quickly,(hyperactively). IHTH Michael Last edited by C. M. Wolf; 12-26-2010 at 07:00 AM. |
Hotrodchevy
great info to share with eveyone i also weld as well sometime so thank you for posted this
2017 1500 CREW CAB GMC 1997 C1500 Chevy 1971 CHEVY CHEVELLE SS 402BB : 1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816 My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650 |
![]() Join Date: Apr 2008
Saw this article about a year ago and immediately went to look at my can of brake cleaner, because I use this method all the time to de-grease prior to welding. The brand sold at Pep Boys "CRC'' does not contain the tetracloroethylene that is in the artilce. I tried this in a controlled environment but could never replicate the white smoke by welding. The flash point of brake cleaner is so fast that it was completely evaporated before the heat got close enough to it. I even tried it in porosity with no problem.
Now I am not saying that this will not happen with other brands but just that it did not with the CRC brand when I tried it. Good rule of thumb when welding in general is to not have your hood in the path of any fumes. Weather welding on galvanized or if you have used brake cleaner, or if you are just welding MIG on mild steel, the fumes created in the process are not good to inhale and could potentially cause damage to you.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 12-25-2010 at 03:33 PM. |
2WD Jimmy
![]() Join Date: Mar 2005
If you wait until the brake cleaner evaporates, it is not a danger.
Posted via Mobile Device |
Thats insane, just shows somethings as simple as that can easily kill you. Why not just wash the area with a degreaser like dawn dish soap while scrubbing it then letting it dry?
1969 Chevy c20(Miss Hackjob) |
great find man! thats good to know because i have been using brake cleaner all day today to get the heavy grease off of my 6.5 td and the frame on the 67!!!!!!!!!!! thanks for posting this up because i was going to use some break cleaner on the frame mounts for my rad support in a few mins because i gotta weld up a few cracks.
04 Chevy Colorado Z71 4X4 76 Chevy C-10 Custom Deluxe (sold) 67 Chevy C-30 1 Ton 9' stepper 6.5 Turbo Diesel |
#11 | |
Thanks again! |
