05-26-2010, 07:40 PM | #1 |
Do I need this bracket?
I'm getting ready to clean and paint the frame of my 65 chevy and I'm thinking of removing this bracket before I do. The truck has an auto trans but doesn't have a shifter yet. I think this bracket was for the clutch z-bar, but will I need it when I install a new steering column with a shifter for the auto trans?
Thanks |
05-26-2010, 07:45 PM | #2 |
Senior Enthusiast
Re: Do I need this bracket?
It is in fact the z-bar bracket. Unless there is a chance you'll be going back to a stick shift someday, it can go.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
05-26-2010, 08:45 PM | #3 |
Are you planning to have this truck buried with you? If not, please think about leaving the bracket where it is. It's not in the way of anything right now, and whoever buys the truck from you might appreciate your thinking about the next owner. I know I would.
Ray Last edited by raycow; 05-26-2010 at 09:02 PM. |
05-26-2010, 08:57 PM | #4 |
I remove the bracket when doing the conversion, so it appears as stock, as possible. It is a dead-giveaway, that the truck was a manual with the bracket in place. My thought is, if it is not needed, it should be removed, especially, if you are painting the frame.
05-26-2010, 09:26 PM | #5 |
I tell you what if you do want to remove it I would love to have it. The moron who had my truck before me butchered mine all up.
05-27-2010, 01:41 AM | #6 |
60-66 Nut
If you're not going to be using it, I would remove it. It will look cleaner without it. But don't toss it, let shark66 have it if you don't want to keep it.
And after you get that taken care of, you might want to take a look at that lower steering column bearing......I think it needs some help. Just sayin.....
05-27-2010, 07:22 AM | #7 | ||
Jerry Last edited by JGross; 05-27-2010 at 07:26 AM. |
05-27-2010, 07:38 AM | #8 |
For that Z bar bracket I am. I would really appreciate it man I have been looking for one for a little while now.
05-27-2010, 08:44 AM | #9 |
PM me your address and I'll send it to you when I take it out.
05-27-2010, 01:50 AM | #10 |
Senior Enthusiast
Good call Capt. Looked right at it and didn't even see it. That's really scary.
05-27-2010, 02:32 AM | #11 |
Looks like the spring is missing to hold the bearing in place
1972 corvette (454-4speed) 1960 corvette (283-2-4barrel-powerglide) 1966 corvette (427-4speed) 1964 chevrolet stepside (502-6speed) 2002 corvette (LS2-6speed) .... http://photobucket.com/rogers-64 under albums click Ineeda |
05-27-2010, 03:05 AM | #12 |
Good eye, Capt.
