Old 02-24-2009, 03:44 PM   #1
timzrides
timzrides's Avatar
Help with Exhaust Routing!
With the search engine down, i need some help with my exhaust plan. I have my frame C-Notched with trailing arms and bags. I'm trying to decide weather to cut 4 inch openings on the center crossmember or run below the center. What are the pros and cons of either. I'll basically have the typical front and rear bagged. thanks
timzrides is offline   Reply With Quote
Old 02-24-2009, 05:52 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Help with Exhaust Routing!
Cut some holes in it bro! As long as you're not running long tube headers, you'll be able to have all your exhaust up higher then the bottom of the frame that way.
see ten is offline   Reply With Quote
Old 02-24-2009, 06:48 PM   #3
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I agree, and If I had not bought the ECE drop Cross member I would be doing the same thing. After airing mine out, the exhaust would surely hit the ground before anything else. By going through the cross member, the lowest point is the bottom of my fuel tank and the big ass front cross member.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 02-24-2009, 08:02 PM   #4
PipsC10
PipsC10's Avatar
I agree, cut holes or contact ECE for a drop crossmember. They also have a nice transmission crossmember that allows you to run the exhaust above it and between the frame.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 02-24-2009, 08:12 PM   #5
fastom
That's right, it's Copper!!
fastom's Avatar
I have both the trailing arm crossmember and the trans crossmember from Early Classic. They both work well and get the exhaust up and out of the way.
fastom is offline   Reply With Quote
Old 02-24-2009, 09:08 PM   #6
shortbed70
shortbed70's Avatar
Cut the holes! I plan on cutting holes in crossmember and welding in 1/4" 4.5" inserts to strengthen the crossmember again then doing another cutout in the side of the frame right behind the front bed mnt to route exhaust out side the frameto the front of the tire. Heres an old pic
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-24-2009, 09:13 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Cut holes in it so that you can route your exhaust thru it. That's what I plan on doing too. Too bad I just put a new 2 1/2" Magnaflow stainless system on it last year.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-24-2009, 09:21 PM   #8
kevncar
Active Member
kevncar's Avatar
Through the traling arm crossmember is definately the way to go.
Can you get the exhaust over the stock tranny crossmember though?? That is what I was hoping to do.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 02-24-2009, 09:24 PM   #9
shortbed70
shortbed70's Avatar
Mine is but its REAL close and if I hit a big enough bump it will clang so I plan on notching it too and making a bridge so exhaust will run below two parts of the trans x member. I don't have the top ears on the trans crossmember that bolt to the top of the frame.
Troy
Big Red Dog build
Old 02-24-2009, 09:28 PM   #10
kevncar
Active Member
kevncar's Avatar
Got any pics? I don't have all my stuff in yet, and the cab and bed and all is off of it, but other than where to put the mufflers, it looks like there is plenty of room. What size exhaust do you have on it? I was going to try and squeeze 3" in there, and try and get it over the rear axle all the way to the rear bumper. I want to run a tank between the rails and all that back there had me more worried than the tranny or trailing arm crossmembers.
Kevin
72 Chevelle
67 C10...454/TH400
Old 02-24-2009, 09:29 PM   #11
kevncar
Active Member
kevncar's Avatar
I was hoping to run more between the top ears of the tranny crossmember and the tranny itself...
Kevin
72 Chevelle
67 C10...454/TH400
Old 02-24-2009, 09:45 PM   #12
QKENUF4U
QKENUF4U's Avatar
cut the holes and it tucks up all above the frame....... wouldnt do it any other way if i do it again....... or get the ECE crossmember they mention.......
QKENUF4U is offline   Reply With Quote
