02-03-2015, 08:24 PM | #1 |
Bolt - on mods from van sourced parts
Scored myself a cheap 1990 G20 for the engine and a few other bits (sway bar being a high priority) but what I'd really like to know it how different the tilt column is from the existing one in my '79 C10?
Also, am I right in thinking that the stock van diff is a limited slip item? Are there any other crafty little things worth swapping over? |
02-03-2015, 08:36 PM | #2 | |
Re: Bolt - on mods from van sourced parts
I have a '92 G20 and a '92 G1500. Pretty sure neither has a limited slip. I know the tilt is at least a little different, the gear indicator is on the column.
I like the serpentine setup on the van, and I thought about seeing how to use the newer style a/c compressor. I would also use the fuel injection, it's a simple system and all I need. If it has the 700R4 I would use that to. Thought about adapting the instrument cluster too.
02-03-2015, 11:40 PM | #3 |
The side marker lenses work for the 68-72 trucks and some vans have the radiator supports for the 67-72 trucks. Also some of the air cleaner risers don't have the PCV tube which can be used. How about van rallys?
02-04-2015, 01:41 AM | #4 | |
The van rallys are 6.5 wide. Still work though.
02-04-2015, 06:10 AM | #5 |
I'm all over the rally's and will have them banded for extra girth
What about the Power steering components on the van? |
02-04-2015, 10:21 AM | #6 |
The van rallys work good for the front and use 15x8 rallys for the back. The power steering pump should work with your box if it is an O ring style box. Any pictures of the van and engine bay? Also the license plate holder on the back bumper works with truck sport bumpers.
02-04-2015, 01:43 PM | #7 |
Be advised that the "old" GVan (ie, 1970 - 1996) is staggered in terms of series compared to what we are used to.
Said differently, a G20 is more like a C10, and a G30 is more like a C20, in terms of brakes, rotors, lug pattern, etc. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-04-2015, 04:49 PM | #8 |
Does that make a G10 comparable to a K5?
02-04-2015, 05:05 PM | #9 |
(...not sure if serious...)
Technically, no - since the van is 2wd and the K5 is likely 4wd. But - yes - it would be comparable to a "C5".... G10 = "light" C10 G20 = C10 (5 lug wheels) G30 = 8 lug wheels K
02-07-2015, 05:04 AM | #10 | ||
I assume the bumpers can't be used which is a shame as the chrome is really good. Anyone ever fitted van or camper bucket seats? |
02-07-2015, 09:22 AM | #11 |
Just looking to see if there are other engine accessories that can be used on trucks. The bumpers are basically the same, but the mounting bracket holes are different. I just put low back van seats in a 78 truck using 87 suburban seat tracks. They look and work great. Some van seats will be too "skinny" to look right in a truck.
02-07-2015, 01:26 PM | #12 |
The engine oil filler and trans fluid dipsticks are elongated in the van it would seem.
Good info on the suburban frames but the hard part is finding a Suburban being broken for spares ('parted out' ) |
