02-02-2011, 10:18 PM | #1 |
What rear end is in my 3/4 ton truck? Pics
I tried a search.. Its different then I've seen. Its a 3/4 ton 68 with coils. It has a rear cover and a third member??? I dont know what it is or if its worth keeping. Wish it was a Dana 60
Crappy pics, thanks for your help |
02-02-2011, 10:24 PM | #2 |
Project Junkie! Fishing Poor!!
Re: What rear end is in my 3/4 ton truck? Pics
That is the eaton (corperate) rear end. We call them banjo rear ends. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
02-02-2011, 10:54 PM | #3 |
20' Daredevil (Ret)
Tough as nails.... definitely worth keeping IMO. Some brake parts are hard to find so guys will swap them out, but if it's in good working order, I'd keep it.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-02-2011, 10:58 PM | #4 |
20' Daredevil (Ret)
Here's a parts diagram posted by board member 1969 GMC:
02-02-2011, 10:54 PM | #5 |
I was wondering if it was the corporate rear.. I'll do a search to get more info.
02-02-2011, 11:26 PM | #6 |
Vintage 4x4s
Its the presence of that 5.284 bearing in the diagram that makes them strong. That keeps good alignment even under high load.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-02-2011, 11:33 PM | #7 |
Second Chance Program
Eaton. They are good and strong.
02-02-2011, 11:48 PM | #8 |
its all about the +6 inches
they are tough as nails, but, outdated.
some brake parts are hard to find, some brake parts you will not find. If it needs rebuilt, you'll have the same issues, and gearing is very limited. |
02-02-2011, 11:55 PM | #9 |
Vintage 4x4s
Roughly what percentage of 3/4 tons had these vs Dana 60's? Were there factors such as 4x4, BBC, that made a certain truck more likely to have or not?
02-03-2011, 12:13 AM | #10 |
Most 3/4 tons got the Dana
many GMCs got the dana most of the rest got the Eaton The Dana, while I know there diffs are pretty good, these 3/4 tons got lame axleshafts, so as a (stock) rearend they kinda suck. |
02-03-2011, 02:01 AM | #11 |
These rear ends make a Dana 60 look like a 10 bolt. Agreed brake parts are hard to find, but a 14 bolt disc brake conversion fixes that. Guys run these rearends in off road trucks with 40 inch tires and have little if any problems with them. If you want to get rid of it let me know, I probably have a Dana 60 laying around I'll trade you. The axles only have 17 splines but rarely break. If they do you can insall 14 bolt side gears and 14 bolt 30 spline axles in this rearend. Keep it, you won't break it on a 2wd truck. Yes it is a corporate rear commonly referred to as an Eaton.
02-03-2011, 08:38 AM | #12 |
Watch out for your cornhole !
I never liked them due to the gearing options. I do believe nothing taller than like 4.11 was available.
02-03-2011, 09:44 AM | #13 |
NAPA has most all of the brake parts for it
02-03-2011, 11:25 AM | #14 |
True 4.10's are the highest gear, but with an OD automatic such as a 700R4 those 4.10's become a 2.90 in OD. 3.07 with a 4L80.
