Collector of Projects
WEIAND 8004 Action Plus Intake Manifold SBC
I purchased this to run on my K5 but never used it. $80 plus actual shipping. Description from the internet...
Weiand Action+Plus intake manifolds are designed for use as stock replacements, with improved power and torque characteristics. They're 180 degree, dual plane types, with a carburetor flange that'll accept either stock or aftermarket performance carburetors. Their effective rpm range runs from idle to 6,000 rpm. With their high-flow runner design, and ability to produce increased power with little modification, it's no wonder these manifolds are so popular. Intake Style: Dual plane Basic Operating RPM Range: Idle-6,000 Intake Material: Aluminum EGR: No Notes: HEI will clear. ![]() ![]() *** I can have this sandblasted and powder coated locally before shipping. Probably $40 but I would have to check on the cost.... I think the also do ceramic coating (not Jet Hot, but ceramic powder) Last edited by mcmlxix; 03-07-2013 at 04:48 AM. |
Re: WEIAND 8004 Action Plus Intake Manifold SBC
Price Lowered - $80 plus actual shipping...
I will need to find a box.... |
Just a Member
Nice informative thread. How do you think these would compare to the 2701 rpm Edlebrock intake??? If it is still available here in a few.. I might take er'...
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
Looks like they're both dual plane with the Weiand having a slightly higher RMP range. I would guess they are close enough that it would be hard to notice a difference... It would depend if you needed the extra RPMs...
ttt.... remember, I can have this custom powder coated any color....
... but I am going out of town till the June 9th... Last edited by mcmlxix; 06-29-2012 at 04:13 AM. |
Bump.... I have a spread bore carb for the manifold that I could throw in for $60....
if you still have this.... Im wondering what type of choke pull off its set up for, it looks like maybe the angled hot air tube, or is it the flat (level w/ the street) bi metal spring found on the early factory spreadbore manifolds, like the '69s? how much to ship to 48609?
refering to the flat boss cast between the center two (intake manifold to cylinder head) bolt holes, in your first photo it sits directly centered under the carburator flange. You may not even have a need for the choke in AZ, but up here we got to have em.
what kind of carb do you have, a quadra jet? do you have the numbers? is it a 4mv, divorced choke or an electric etc? pics?
Picked up an edelbrock, thanks anyhoo
#17 |
I can sand blast this for free..... if you're not in a huge hurry....
#20 |
Did it ever sell?
#21 |
No, I stashed it on a shelf... If you're interested I need to find a box for shipping....
#22 |
What's the best you can do shipped to 95368? Thanks
