Old 11-15-2024, 09:46 PM   #1
Railroadman
Railroadman's Avatar
Front hub - do I have a problem?
'66 C20. I'm seeing 2 lines inside the hub, diametrically opposite each other and each centered on the square notch. I THINK they are something from casting or machining, but want to be sure they're not cracks. Opinions?
Railroadman is offline   Reply With Quote
Old 11-15-2024, 11:23 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Front hub - do I have a problem?
Cast metals do not usually crack only partway, they don't really flex - they just crack completely. What does the other side look like? Any cracks on the machined surface?
You could hang it by a wrench or on a nail and give it a wee rap with a hammer - if it rings, it's likely fine, if it's more of a thud, it may actually be cracked.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 11-16-2024, 10:33 AM   #3
Railroadman
I believe you are right, the opposite side does not have any "crack" extending, and looking closely it appears there is actually a slight bevel or "V" shape to it. When I get to the other one I'll clean it up and look at that one closely, my bet it they will both have the same marks.
Thank you!
