01-29-2011, 09:18 PM | #1 |
Need new fuel line, suggestions???
I need to put a new fuel line in my truck, the PO kinked it but never told me and found theres a lot of rubber line that scares me. I havent noticed any power loss or sputtering but just want to be safe rather than sorry so im wondering what kind of fuel lines do you guys use, and how do you do it?
1969 Chevy c20(Miss Hackjob) |
01-29-2011, 09:57 PM | #2 |
Retired Air Force Veteran
Re: Need new fuel line, suggestions???
I decided to go with Steel Braid AN-6
Here, the Steel Braided Line ends and converts to 3/8" hard lines to the in-cab tank
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
01-29-2011, 09:59 PM | #3 |
How do you like it? Was it a lot more exspensive?
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 01-29-2011 at 10:00 PM. |
01-29-2011, 10:02 PM | #4 |
Watch out for your cornhole !
I use the long pieces of 3/8 hard line from the parts store. Cut and bend as needed. It runs about a buck a foot. I warn you, that AN hose the guy posted above is pricey.
01-29-2011, 10:37 PM | #5 |
The -AN fittings are what cost the most, oh and the double rail on the carb was about $80. I figure I have about $300.00 from the carb to the in-cab sending unit.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 01-29-2011 at 10:37 PM. |
01-30-2011, 10:24 PM | #6 |
I've got a #10AN coming out of the tank, reduced to a #8 thru the pump and filter, to the carb. The braided is top dollar, but is very abrasion resistant, and lasts a very long time. I had a braided radiator hose that I had on every Chevy I ever had for 25 years!No failures. No Bull!
02-01-2011, 04:10 PM | #7 |
Here's a pic of what Tx Firefighter is describing. Hopefully it helps.
01-30-2011, 01:12 AM | #8 |
Wow thats a little pricey for me this truck is going to be a DD and not fancy, but it does look awesome.
01-30-2011, 07:30 AM | #9 |
its all about the +6 inches
an stuff is expensive and uneeded 99.9% of the times on street bound vehicles. Most people buy it becouse it's pretty and they see the guys on the race track use it. They are also real easy to take apart and reassemble once you have everything all figured out.
There is no reason not to do what Tx said up there. Steel fuel line will last 30 to 60 years ... give or take. |
01-30-2011, 09:39 AM | #10 |
you can use the regular steel lines or there is a new type with an alloy that is easier to bend from what i've read tho i've necer used it myself but will try it the next time// ask at the autoparts store about it (sorry dont know the name)
i start at the pump, i'll use a piece of 1/8 rod or coat hanger as a template to get the first bend from the pump up to the block and going up/that is the hardest section to get right after that it's just a couple of simple bends
01-30-2011, 02:37 PM | #11 | |
01-30-2011, 10:38 PM | #12 | |
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
02-01-2011, 03:30 PM | #13 | |
I did what Hubscrub did and bought some of the new ez-bend green brake line to run a fuel line from the pump to the carb but couldn't get the new fittings to stop leaking. The guy at NAPA told me, "Oh yeah, brake and fuel line fittings are different," but he didn't have any hard line fuel fittings so I had to cut the new hard line and feed the fittings off the old fuel line on the line, which stopped the leaking but looks like crap. I want to redo it and would like to use the new fittings that come on the brake line, but am now confused and gunshy. I can't imagine that they're really different and others don't seem to have this problem, so maybe I just got a bad line or something? Thanks everybody.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
02-01-2011, 09:34 PM | #14 | |
Cruzin
02-01-2011, 09:46 PM | #15 |
You can get 3/8 aluminum fuel line from Summit.
01-30-2011, 08:55 PM | #16 |
I think they call it green hardline. It is very easy to bend and I think it's even cheaper than normal hardline.
02-01-2011, 03:37 PM | #17 |
yeah ... most common fuel line is 3/8" ... most brake line is 3/16" ... big difference.
02-01-2011, 04:03 PM | #18 |
I don't think they are different... I used 3/8 napa lines on my burb, they said brake line when I got them, but I can't say 100% they were actually listed under brake line.
02-01-2011, 04:27 PM | #19 |
02-01-2011, 04:38 PM | #20 |
I have all the pieces to do my fuel system I havent done it yet my fuel cell has a -8 outlet (have a fuel cell mounted under the bed) I have a reducer going down to -6(3/8) then a 90 degree with a barb fitting im going to run rubber line to a fuel filter then to my electric fuel pump then to the frame rail were im going to run a aluminum 3/8 line all the way up to the front then I will run rubber line to a clear fuel filter then up to my carb im useing barb fittings or flared ends everywere I atach the rubber line. rubber line will work just fine it wont last 50 years like metal line but much easier to work with and alot less fittings to deal with just cheep hose clamps and nothing special you have to order you can pick it all up at your local parts store
02-01-2011, 05:32 PM | #21 |
Autozone sells copper line which is what i plan on using!!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
02-01-2011, 05:52 PM | #22 |
copper is not a good idea, no real advantage to it either.
02-01-2011, 06:01 PM | #23 |
Man of Mini-Talents
I purchased a premade set from Inline Tube, about $65, $80 if you want stainless. Fit perfect.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-01-2011, 06:04 PM | #24 |
Do you have any pics of it? I would love to see it! Thanks.
02-01-2011, 06:21 PM | #25 |
Man of Mini-Talents
