11-13-2017, 03:12 PM | #1 |
Factory gauge question.
Hey everyone. I am planning out a 5.3 swap into my 72. Wondering what I need to do to connect the factory 72 gauges to the motor. Where do I connect for the oil pressure and can I make the LS temp sensor work with the 72 gauge or will I need a different temp sensor.
Thanks. |
11-13-2017, 04:19 PM | #2 |
Re: Factory gauge question.
On my 66, I took the factory oil pressure sender for the 5.3, gutted it and drilled and tapped it for the copper line to connect to. Some have done it this way and others have run it down to the block off plate near the oil filter. I highly recommend NOT going with the Ebay banjo fitting adapter under the LS oil pressure sender. Mine leaked like crazy and couldn't get it to not leak. I used an 02 engine so I didn't have the oil pressure sender needing to send a signal to the computer.
For the water temp, I bought an adapter for the plug in the passenger side head at the back and machined and rethreaded my factory sender to 3/8 NPT so it would thread into the adapter. I'm not too far from you and you're more than welcome to swing by my place and check my swap out if you'd like. |
11-13-2017, 06:28 PM | #3 |
Thanks for the reply, machining the old temp sender is outside of my resources. Repurposing the oil sender will be east enough. May have to take you up on your offer.
11-13-2017, 07:07 PM | #4 |
autometer makes adapter kit for LS swaps...https://www.summitracing.com/parts/a...hoCOX8QAvD_BwE
11-13-2017, 07:11 PM | #5 |
blazer has some temp sensor mods...http://67-72chevytrucks.com/vboard/s...d.php?t=726700
11-13-2017, 09:32 PM | #6 | |
11-13-2017, 09:39 PM | #7 |
I bought that kit and wound up only using the oil pressure metric to standard adapter bushing ....I changed all my gauges to mechanical. ..
11-13-2017, 08:35 PM | #8 | |
11-13-2017, 11:05 PM | #9 |
That temp sender wont be accurate for a factory gauge. It may move the needle a bit, but probably wont give any usable info. I just drill and tap the passenger side head for the factory '72 sender to screw into, quick and easy.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-13-2017, 11:20 PM | #10 |
I did the same as ls1nova on mine...drill and tap pass head...
