Good way to lower
What would be the best way for me to lower my rear end of my 1969 longbed. I really dont want it to look like a stink bug any more so what would be the best way to lower it about 2" or so just to get the stink bug look from it and i really was thinking on just cutting the coils. So what do you guys think.
It'll ride much better if you install 2" dropped coils vs. cutting...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
You said you just want to lower the rear of your truck? Because the springs have pig tails on each end, cutting the springs would take alot more work. I would either buy or make some 2 inch lowering blocks to put between the trailing arm and rear end. To make sure this would work alright, whats your rear tire diameter?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
![]() Join Date: Dec 1999
cutting the rears arent like cutting the front you should get the ends re twisted,but i think id go with blocks,or drop spring or the ultimate el cheapo way el torcho get them hot,real hot.
Almost Satisfied
![]() Join Date: Mar 2002
I will have some 2" blocks available in the near future if you are interested. I am buying new springs and will not need the blocks. If you are wanting to do something right away I can't help, but let me know.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Now the others dig........
![]() Join Date: May 2002
How easy is it to remove and replace the coils???I'm thinking of lowering my rear also.....actually, my parts truck has lower rear coils than my project, so I was thinking of switching them. Could shocks make a difference in the rear ride height?????I have coil shocks on my truck, and regular gas shocks on my parts truck.
Is torching the rear springs a good idea, is that a good way to do it???? I can get a torch.... ![]()
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 Last edited by SWINGSAX68; 07-25-2002 at 01:28 PM. |
Fabricate till you "puke"
in a word....NO, heating springs to drop is not a good idea. heating destroys the temper of the spring........Al
Unregistered User
![]() Join Date: Dec 2001
It's really easy to swap the rear springs (provided you can free the nuts on the spring retainer bolts), and you can get a new set of drop coils for around $115 or less.
Just remove the shock, support the trailing arm with a floor jack, and remove the retainer bolts. I did break one of my top retainer bolts, so prepare to have to replace some. I've heard some guys have had to cut them off, but I didn't have that much trouble. If I was going to do it again, I'd have new hardware ready to put on.
71 SWB Stepside SB400/TH350 |
I don't recall what the setup looks like right now, but where would I be able to buy these bolts and stuff to replace them......which I plan on doing anyways. Do they have them at auto parts stores?????
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
