10-26-2009, 10:53 AM | #1 |
dip stick won,t stay
My dip stick is loose on my 350,what can I use to make it stay that will take the heat etc
10-26-2009, 11:04 AM | #2 |
Formerly- 1972SuperCheyenne
Re: dip stick won,t stay
The dipstick is supposed to press into the block. If it doesn't stay, just replace it with a new dipstick. You can probably get a chrome one from Advance/O'Reileys for $10-$15 bucks.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
10-26-2009, 11:09 AM | #3 |
it is a chrome one I can,t find the old one
10-26-2009, 01:04 PM | #4 |
Loose where?
You mean the tube won't stay pushed into the oil pan or the indicator stick won't stay pushed into the tube? Tube in oil pan: Put some RTV around the base of the tube and push it in. Stick in the tube: you could crimp the shield slightly so that there is some resistance to putting it in. Or, in some high performance applications where the blow by in the crankcase is pushing the stick out - some guys have taken a short piece of hose or rubber and put it around the stick and the tube, clamping it with small hose clamps. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-26-2009, 03:38 PM | #5 |
find a new girl
10-26-2009, 05:10 PM | #6 |
could be blow by.if i'm understanding your description.
" Never look up a dead dogs butt." |
10-26-2009, 09:25 PM | #7 |
if the hole dipstick tube is wiggling around in the block just pull it out and SLIGHTLy crush the tube where it goes into the block, but not down by the end. then a little rtv and slide it back in
"I'll keep my guns, money, and freedom. You can keep the "change" |
10-27-2009, 10:48 AM | #8 | |
1962 C-10
I agree. Those chrome one's never seem to fit tightly. When I installed those, I usually taper the tip on the bench grinder, then use a little RTV and tap it in. Tapering the end to get it started usually helps for some reason on those 'chromies'.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
10-27-2009, 10:44 AM | #9 |
thanks it,s just a cheap peice of crap,no blow by or nothing its the tube into the block
