09-01-2004, 06:59 PM | #1 |
Which ball joint-disc conversion?????
Hopefully an easy answer. I have a set of 78' 1/2 ton spindles that I want to install on my 68' 1/2 ton a-arms.
Which ball joint should I use for both the upper and the lower a-arm, the 71-72' style or the 73' and up? Will I need to change the a-arm to a newer version to complete this conversion? Thanks!
Dennis 68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . . Last edited by dennis111; 09-01-2004 at 07:13 PM. |
09-01-2004, 08:49 PM | #2 |
Watch out for your cornhole !
Buy the ball joints for the 78 spindles and install them into your stock arms. They interchange without any mods required.
